Ok... After a year of owning the car with no problems whatsoever...i have finally came across one.
Problem that i'm having is -- the battery seems to be draining heaps quickly.
i have not driven my line for 5 days... so i assumed due to the cold weather..of course we get that awful cold start..i tried starting my car-- no luck.. till it just pretty much drained the battery. ( u get that "click click click " noise everytime u turn ignition on )
so i assumed battery was dead..i had it jump started and it went ok..started.. took for a 30min drive around town.. went to the supermarket for an hour.. when i got back.. the darn thing wont kick in.-- dead battery AGAIN.. so i jump started and worked OK. -- this i assumed the battery needs replacing as i had it ever since i bought it.--- so i got me a new one.. one click and the car started.. no problem. -- now went home and tried starting the car -- 4 tries and NO LUCK.. kept trying till i hear that " click click click " noise -- battery dead again.
i dont get it.. its fine when i jump start it.. starts pretty easy... but when i leave the car off for just 2 hours..it wont start.
I ruled out the alternator coz i had that problem with my previous car and the symptoms are not the same.. the car runs well..using aircon on / stereo and head lights.. nothing i know of that signs of alternator problem.
could it be the starter motor ? :confused:
Anyone who had the same problem and would be of help would be appreciated
thanks.
https://www.sau.com.au/forums/topic/80824-rb25det-power-drains-help/
If you've got a multimeter, put it in series with one of the battery leads and measure the current draw with key OFF. Should be close to 0. Anything more than 1/2 to 1.0 Amp will drain the battery pretty quick.
Is the battery voltage around 14v with the engine running?
If it jump starts OK, i'd doubt it will be the starter. Sound more like a lack of voltage problem.
hey does it just click or does it crank really slow??
plus double check the starter & battery terminals also you may have a volt drop on the switch wire to the starter
when you mean its flat are you sure its flat like are you head lights dim??
will your radio work??
if they do well could possible be starter related
just went and check the boot light and it was fine.. doesn't stay on.-- all terminals are fine.
and yes.. i can still play the radio / stereo and some lights.. but it just wont crank up.. and when it does.. it is slow.
could be a voltage drop.. dont think its the starter as it fire up fine when hooked up to another batery.
now.. how to fix this voltage drop..??
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
