Valvoline filters are bad. Far from being high performance. lol
I wouldn't go past genuine ~$no idea, Purulator (~$7), PureOne ~$14.
I'm currently running Mutol 8100 5w40. Its a pretty damn good oil but I am considering making the jump to Castrol 10w60.
  • 5 months later...
You may wanna check ur oil pump, stick a proper oil gauge on it and get a reading, i had a VS commonhore that the oil pump was farked, no reading on the gauge unless revved i jus thought it was faulty gauge until i had it checked by a mech and got same reading. Stupid me did nothin about it and the car survived for another 5 months until it spun a rear main bearing and destroyed my engine when my oil pump finally died..... and with the ticking my R33 has also jus started to do this at idle not really noticable until you go into a surrounded area, but oil pres seems fine.
Has anyone actually resolved their ticking dilemma?
good reply champ.
yes. out of all these people i think its a bit obvious stright away saying it goes away when you hit the gas pedal is because the oil pump works a bit harder to give it oil pressure thought the engine and the gauge reads 0 when its idling but gives a reading when you get up the revs..that my guess is oil pump for sure esspesially if the gauge use to work and there was no noise now there is noise and the gauge not working is to coincidental...
keep stock oil filter from factory nissan cant go wrong
Hmm... I have an R32 that gives out wierd oil pressure readings.
What should the reading normally be? if it's getting close to 0 when say i'm on the highway at constant revs is it something to worry about?
I don't have any noise coming from my engine like the other guy, i'm just abit curious as to why my gauge move around so much...
Yes i would be worried, mine generally sits close to 4 on the highway and drops to 1st notch on idle once everything is hot and the car is stopped. Jus cause its not making noise dosen mean anything, it will start making noise once it spins a bearing... i would be taking it to a mech and get a proper oil gauge reading straight from the block and if its the same replace your oil pump ASAP!, as they do wear out and is VITAL to ur engine surviving. Right now you are probably starving your engine of oil and it wont take it for long. If you cant afford straight away change to a much thicker oil for the time being to get some pressure back, but be warned the thicker oil will put more strain on your pump again. Hopefully its a dodgy gauge but very unlikely.
Edited by PowerupZ
Actually I think it is a dodgy gauge..
I watched it closely on the highway last time... it sits at about 2 when cruising... then all of a sudden will flicker down to 0, then straight back upto 2..
She will be going in for a service very soon so i'll have her checked out then..
Cheers!
2 sounds pretty high for idle once the engine is warm and has been driven around a bit. When mine is cold or jus warmed and haven flogging it, it will be like that. But generally once i have drove it for a while idle will be jus above 1. What grade oil are you using? Rev is normal at 4 for all the liners i have driven.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
