Valvoline filters are bad. Far from being high performance. lol
I wouldn't go past genuine ~$no idea, Purulator (~$7), PureOne ~$14.
I'm currently running Mutol 8100 5w40. Its a pretty damn good oil but I am considering making the jump to Castrol 10w60.
  • 5 months later...
You may wanna check ur oil pump, stick a proper oil gauge on it and get a reading, i had a VS commonhore that the oil pump was farked, no reading on the gauge unless revved i jus thought it was faulty gauge until i had it checked by a mech and got same reading. Stupid me did nothin about it and the car survived for another 5 months until it spun a rear main bearing and destroyed my engine when my oil pump finally died..... and with the ticking my R33 has also jus started to do this at idle not really noticable until you go into a surrounded area, but oil pres seems fine.
Has anyone actually resolved their ticking dilemma?
good reply champ.
yes. out of all these people i think its a bit obvious stright away saying it goes away when you hit the gas pedal is because the oil pump works a bit harder to give it oil pressure thought the engine and the gauge reads 0 when its idling but gives a reading when you get up the revs..that my guess is oil pump for sure esspesially if the gauge use to work and there was no noise now there is noise and the gauge not working is to coincidental...
keep stock oil filter from factory nissan cant go wrong
Hmm... I have an R32 that gives out wierd oil pressure readings.
What should the reading normally be? if it's getting close to 0 when say i'm on the highway at constant revs is it something to worry about?
I don't have any noise coming from my engine like the other guy, i'm just abit curious as to why my gauge move around so much...
Yes i would be worried, mine generally sits close to 4 on the highway and drops to 1st notch on idle once everything is hot and the car is stopped. Jus cause its not making noise dosen mean anything, it will start making noise once it spins a bearing... i would be taking it to a mech and get a proper oil gauge reading straight from the block and if its the same replace your oil pump ASAP!, as they do wear out and is VITAL to ur engine surviving. Right now you are probably starving your engine of oil and it wont take it for long. If you cant afford straight away change to a much thicker oil for the time being to get some pressure back, but be warned the thicker oil will put more strain on your pump again. Hopefully its a dodgy gauge but very unlikely.
Edited by PowerupZ
Actually I think it is a dodgy gauge..
I watched it closely on the highway last time... it sits at about 2 when cruising... then all of a sudden will flicker down to 0, then straight back upto 2..
She will be going in for a service very soon so i'll have her checked out then..
Cheers!
2 sounds pretty high for idle once the engine is warm and has been driven around a bit. When mine is cold or jus warmed and haven flogging it, it will be like that. But generally once i have drove it for a while idle will be jus above 1. What grade oil are you using? Rev is normal at 4 for all the liners i have driven.
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
