  • Replies 61
I'd take the Chaser, but I'm a big fan of R34 sedans too.
looks - about the same. I think they both look awesome, but in different ways. The Chaser is more of a luxury look, whereas the R34 is sportier.
performance - JZX100, but only just. 378Nm from 2400rpm versus 343(s1)/363(s2)Nm at 3200rpm is just in the Chaser's favour.
fuel economy - about the same I think.
potential - not sure what you mean here, but both engines are highly moddable if that's what you meant.
reliabilty - Toyota quality :P Nissan are good too, so I'd say about the same.
One big thing for me was resale price. Sedans often sell for a lot lower if they have a coupe equivalent. There's no coupe Chaser, so I'd say it would hold its value just a bit better. Then again, they cost more to buy in the first place, so it probably evens out.
I'm amazed nobody has compared the interiors yet :)
Here's a pic of mine. The original pics from Japan were terrible, so I thought it the series 2 JZX100s were pretty much the worst interior you could get in a car, but when I sat in it for the first time I changed my opinion very quickly.
The carbon fibre is very nice and suits the car really well, and the seats have a nice feel to them. The pattern on them isn't too special, but it's a lot nicer than I first thought.
A manual R34 Sedan weighs 1430kg and a manual JZX100 Chaser weighs 1480kg, so there's a good 50kg difference. I think the extra 35Nm and torque lower down the rev range would pretty much even it out.
Handling wise, I have no idea. I've never driven an R34 (or my own Chaser for that matter :))
EDIT: The autos are a different story. R34 = 1450kg, Chaser = 1490kg, but the auto R34 only has 333Nm. So if you're after an auto one, go the Chaser.
Chaser is hot Shane, but the R34 with the Eastbear GT-R front/kit will look damn insane and I think, in the same colour as the chaser, will turn a shitload more heads... if that's what you want!
Who can not gawk at an R34 GT-R when you see one on the streets? They have so much street presence that's for sure.
It's a little unfair to compare those two cars, as obviously they have had tens of thousands of dollars thrown at them. You'd really have to compare stock look to stock look, and I think the R34 has the edge there as look different to most cars out there.
The chaser has many cues to other cars out there. Many might not even draw an eye unless you know what you are looking at. I've seen a couple of stock looking ones out there, and often hard to distinguish it from a Camry from a distance (the ultimate insult! sorry :D)
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
