Just did this yesterday as Ive done on a few NA cars.
Bottle of Redex injector treatment, pull vacuum hose. Rev car to 3k rpm and place vacuum hose in bottle and regulate flow.
This burns the carbon off pistons, valves etc. Car blew out smoke for a while as it should. I only did a small dose on it and the little pinging that it had before is gone.
But I just thought with the turbo in the way of the exhaust is this not a really good thing to do. I guess all the carbon should have burnt and just turned into smoke before it hits the turbo. Any thoughts. Car is fine and feels good - just wondering if this method is no no for turbo car.
https://www.sau.com.au/forums/topic/80907-decarbing-engine-turbo-car/
ive done it to my 33, no dramas.
we do it all the time at work... it wont hurt the engine, as it introducing more hydrocarbons, making it run richer... the white smoke is unburnt hydrocarbons...
its good stuff.
cheers
Linton
Thanks mate - thought it should be ok but the reassurance is good. Right, so the smoke is only from introducing more combustables for a given air supply causing more unburnt HC to exit the exhaust as there isn't enough obxygen there to complete combustion. Smoked for a while as I left the house to take it for a drive. People must have thought what a bomb!
I thought some of the white fumes etc was the carbon. Or is the carbon just going to flake off..not really sure but the car feels better.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
