Just did this yesterday as Ive done on a few NA cars.
Bottle of Redex injector treatment, pull vacuum hose. Rev car to 3k rpm and place vacuum hose in bottle and regulate flow.
This burns the carbon off pistons, valves etc. Car blew out smoke for a while as it should. I only did a small dose on it and the little pinging that it had before is gone.
But I just thought with the turbo in the way of the exhaust is this not a really good thing to do. I guess all the carbon should have burnt and just turned into smoke before it hits the turbo. Any thoughts. Car is fine and feels good - just wondering if this method is no no for turbo car.
https://www.sau.com.au/forums/topic/80907-decarbing-engine-turbo-car/
ive done it to my 33, no dramas.
we do it all the time at work... it wont hurt the engine, as it introducing more hydrocarbons, making it run richer... the white smoke is unburnt hydrocarbons...
its good stuff.
cheers
Linton
Thanks mate - thought it should be ok but the reassurance is good. Right, so the smoke is only from introducing more combustables for a given air supply causing more unburnt HC to exit the exhaust as there isn't enough obxygen there to complete combustion. Smoked for a while as I left the house to take it for a drive. People must have thought what a bomb!
I thought some of the white fumes etc was the carbon. Or is the carbon just going to flake off..not really sure but the car feels better.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
