Hey guys
The old man has a 2002 330I BMW that is about to come out of warranty.
The whole time he has had it he has wanted a little more power (he is a Ex Pro Drag Racer). Only prob is he has spend most of his time on Carby's.
We have figured that the best things for him to do would be.
1- Exhaust
2- Intake
3- ECU Chip
4- Sat navigation
What I would like to know is. What type of exhaust would be best on the BMW? He does not want something noisy but wants it to have a bit of bite.
Intake. Pod filter or K&N Panel filter with CAI?
ECU Chip - Where to get this done? What can be expected from it? Is it safe?
Sat Navigation - Is there a system that will hook into the factory TV/Stereo system? It was a 3K option 3 years ago that he thought he didn't need. Now he wants it but doesn’t believe its worth 3K
Thanks guys
https://www.sau.com.au/forums/topic/80923-330i-bmw-upgrades/
Im not sure if its possible to retrofit the bmw sat navi into the car again
regardless im sure that no aftermarket sat nav can blend seamlessly into the the tv screen on the car.
With regard to power, i think the best power up option will be an ESS supercharger kit that gives the 330 more torque than an M3.
Go on the net and seach for ESS supercharger. I think u can find it on www.my330i.com
total tab for that should be abt 10k aud
Cheap ECU upgrade: http://www.mth-powerchip.de/
Get the cable, pay for the software then copy your existing DME map then send it to the guy named Franz. Tell him what it's got etc then he will send you a new map for you to upload. All up, $200.
There's quite a few different intakes available but the Gruppe M probably looks the slickest. Hope this helps.
    • I might have to shoot them an email. Pity the exchange rate is so bad at the moment. BTW, thanks for posting that table makes interesting reading.
    • Add these Sensors -Wideband, Oil Pressure, Fuel pressure, Intake air temp Good inspection of ignition system of coils, plugs and loom (12v feed and good ground)- a r35 kit is best bang for buck upgrade. A decent tuner should be able to see any issues with the trigger system- a link has good filtering but a good simple upgrade is the nz wiring bolt in kit. Check and replace all the fuel filters- you would be surprised at intank filter after a few years. Also good to check for any leaks on vac hoses and pipe work as has been said. No need to go overboard and spend big $$$ to enjoy the car. A quality tuner is getting harder to find as anyone with a laptop thinks they are a tuner. A link has great features to check sensor voltages and frequency inputs and easy to see live by pressing f12. The link can do a TPS & RPM fuel/ignition mapping on ITB cars then add a 4D table with MAP and ability to add a 5D to it (can help with economy at cruise with wheel speed vs TPS) Where are you located as that will help narrow down a good tuner ?
    • Reviving an old thread, I reckon my stagea is starting to slip. Car usually gets parked on a hill, narrow driveway so cant go up the driveway smoothly, anyhows, lately first gear feels "sluggish"? Not responsive. Feels like I gotta run the engine more than usual to get off the line...  Any recommendations for transmission servicing in Sydney? Or possibly just an excuse to go manual ?
    • Well, moulded carpets should fit well if the buck they use is the right shape. The finish is then just a case of stiching the trim around the edges. Shuoldn't be too hard to get it right. Back in the day, replacement carpets were all "fitted", in that they were stitched together, with cuts and slices taken out to make them form the shapes. Many more opportunities to get it wrong, hence all the concern over good vendors and bad vendors.
    • A timely blog via AASA (keeping in mind they sell brake fluid of course...) https://www.msbgarage.com/blog/news-and-blogs/brake-fluid-what-should-i-use/
