Hey guys...
I currently own an eb falcon I6, and was looking into purchasing a r32 gtst (seeing as i cant afford a xr6turbo ba), and was reading through some posts on here and was amazed at you guys considering a gt35/40 turbo big? The stock ba xr6t runs this (please i am not mocking im jus interested), the falcon runs a 4 litre i know but an rb30 is alot more high tech then the falcon (even older falcons like mine are running lot bigger turbos with full boost at 3000ish), there shouldnt be such a problem with spooling times on these engines.... Anyways how much should i be looking at spending on a good condition r32 gtst. Im looking for mid 12second quater pass while normal street drivability, how much in mods (i want a really reliable car too) should i be looking at and more important WHAT mods would i be looking at id really like to show my mate (in the turbo falcon) how its done again.....Thanks guys
https://www.sau.com.au/forums/topic/80928-curious-about-a-r32-gtst/
Comon guys somebody gotta know how much it'd cost to get a r32 gtst into the 12s and be reliable...
noone can give you an exact price, as prices vary everywhere you go, and vary depending on the condition of your vehicle and its weak points and strengths. It also depends on how you chose to go about your tuning and modification.
Hi 12's or lows 12's?
If you want low to mid 12's youd be up for at least 5 -10 grand on mods i think maybe more. My opinion, get rid of the RB20 and out in an RB30/25 hybrid. I think it would work out cheaper than working the tits off the RB20, your decision. There is a thread on how to do this (R33 RB30 Conversion), i am currently sourcing parts for mine now.
if times are your only consideration, buy a pre-modded R32GTSt and go from there
otherwise the cost won't be worth it
the strengths of the R32 aren't its quartermile times. take one for a drive through some corners, and give the brakes some workout... compared to your falcon (and the BA) and you will be amazed at the braking and handling...
oh, and the difference between a 2L engine and a 4L engine is that its double the size... that's double hte exhaust gas to spool up a turbo. Thus you can expect that a fair sized turbo on a 4L will be large on a 2L.
Its like getting a truck turbo off an 8L engine and bolting it to a BA XR6T... it will be laggy as a mofo. why? its half the capacity...
Warren.
Or buy my car for 22K:) Instant 12s:)
Its prtty easy to get 12s out of a GTST, but its never cheap. The following prices are isntalled prices:
- Intercooler , $1500
- Full exhaust, $1500
- Clutch and flywheel $1200
- GTR injectors, $300
- Pfc and tuning $2000
- Filter and fuel pump $500
- Rear bushes and alignment $200
- Turbo setup. $4,500
- Tyres $800
All bolted to a std Rb20 should see you supporting between 220-250rwkws and doing guaranteed 12.9s and lower. If i can do a 12.9 with a high 2.2, almost 2.3 60ft then a 12.3 is easily on the cards, especially since the car can run 115mph.
Of course if you can pick up a car with the exhaust, intercooler and susp already then you save yourself a nucket of money. And of course you can get the above gear cheaper, and install yourself to almost half the cost, but thhe above prices are more the norm for good gear
This is the fastest R32 gtst that I could see the the SAU timeslip database, and this only just cracks a 12:
http://www.skylinesaustralia.com/forums/me...ails&userid=462
And here it is for sale:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=68602
IMO if you want to run that time and you want a reliable driver, then this is the sort of thing i'd be looking for. You could spend a lot more than the $20k that Roy is asking getting to this point.
EDIT: And Roy beat me to it :thumbsup:
LOL..i often wondered that drag info went to, now i know.:thumbsup:
The 60ft time wasnt as bad as i thought. The car can do consistant 13.2s all day with walking the car off the line, grabbing 2nd then getting stuck into it. Usually a 2.4 60ft:(
It shows that the 12.9 was the quickest because that was my best 60ft time, but it wasnt my best mph.
Having listened to ppls words of caution and reservations about gearboxes...im now confident that they are fine at this power level. R31_Nismoid gave a 20 box a pasting with more power then me behind an RB25 for a good while, mine is still fine. Cubes is running one behind his RB30 making 170rwkws, but typically its the torque that hurts them so if its happy behind the 3.0L:)
So before i part with the car im going to give it another go at the drags...i cant even remember if i was running 15 or 18psi...either way if i leave the line with 5,000rpm with the new RE55S and dont granny 2nd gear, then i will be amazed if i dont easily improve on the 12.9
... time to prove it :thumbsup:
LOL...this is a discussion forum..so i dont have to prove anything :Pimp2:
... i dont care about having the fastest car...i list all the dramas and info not to be making excuses, but to give others an idea of how their car would be quicker if they addressed some of the shortcomings of my car... lol does that make sense?
It will be up to the next owner to enjoy the car..if he/she cars about proving the car still has a fair bit in it then cool...otherwise it is what it is.
lol i wanna open an R32 shop, like R31 House in Japan. Once you get your head around the R32 GTST they are pretty quick cars if you know where to spend the money:)
yo roy
i'll be down at the SAU NSW drag day 31st July to see what time the r32 gtst can with a 2530 and support gear. Not making as much power as you Roy but hoping for a flat 13.....maybe abit optimistic. :P
Will good to compare numbers with your setup.
Cheers
hehe, wasn't that serious - just curious myself as to what is possible. Somebody here should be able to get a mid-12 from a stock internal RB20.. afterall buzz-box powered SR20 and CA18 powered dattos are getting mid to high 11's... and they weigh about 400-500kg lighter
:uh-huh:
a 12 second R32 GTS-t wouldn't exactly street "driveable" off boost...the turbo lag would suck hard...RB25/26/30 transplant would be the most cost effective mod IMO.
LOL...i know im not going to convince you otherwise, but you would be amazed just how driveable they are...a few SAU guys and gals have driven my car when im under the weather and none of them have seemed to mind.
Sure its not as massivley responsive but...i dont recall who in NSW has driven it, perhaps beer_baron drove it???? Doughboy has, its very streetable off boost and has very good manners on the street!
Its no RB25 with 2530 but there is no way you can say its not streetable...that statement is way off the mark.:P
You would be surprised. R32_Bigboy didnt seem to mind too much putting around town in it and he is an RB30 groupie:)...i recall him being surprised how it drove...and he could be heard screaming "GATE IT" like a cast member of One Flew Over The Cuckoos Nest whislt he terrorised a small country town:)
So im a scratched record, if you want big torque and want to put around under 3,000rpm then go the RB30, but dont go around saying RB20s arent streetable...that is just an old wives tail...hell give me $2200 and i can show you an 11second RB20 that is streetable off boost:)
I think you are mistaken thinking the R32 has a 3litre rb30e it infact has a 2 Litre Rb20det which indeed does make it need a smaller exhaust wheel hence smaller turbo.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
