I'm after the little white part that goes from the speedo cable to the back of the actual speedo. It's a little cylinder, white plastic, with a square piece that comes out the tube that actual drives the speedo unit. There's a spring that comes out of the other end. It's only 5cm long. I can provide a photo. This part normally stays in the speedo cable when the speedo unit is removed, but mine came out and broke.
https://www.sau.com.au/forums/topic/80944-r32-skyline-speedo-part/
    • yeah, there's a country that recently started importing Skylines, I blame them.
