Guest JPD Baraba
shell is right
i am agreeeing with the reasons you guys left
i do feel for you guys in aussie
the people here dont want the sdu to get a bad name which is why they want to control it in aussie
however i belive that there is enthusiast in aussie who would not let this happend anyway but people here dont seem to trust anyone
i really do hope you guys can get something started over there
danijel (aka bizkit)
https://www.sau.com.au/forums/topic/81-sdu/
danijel (aka bizkit)[/quote:4b05d407a5]
Don't blame them one bit. At the same time, no one here is going to be a part of it if they want to control it. Like skyzer said, the name isn't registered here so we can form our own club.
I think it's best if we worked together though, not them controlling us. Success in numbers!
https://www.sau.com.au/forums/topic/81-sdu/#findComment-2153
Guest Impul 25T
I think it's best if we worked together though, not them controlling us. Success in numbers![/quote:b485d655da]
I don't believe that the NZ'ers want to control the whole deal, the forums thing was just needing a big clean up. I think if you were to ask, you would find that they are happy for you's to use the SDU name, be affiliated, but still be your own entity.
https://www.sau.com.au/forums/topic/81-sdu/#findComment-2154
Impul 25T,
Dude, I'd love to be a part of some affiliation with them. They have been through everything that we will be going through shortly & we can learn so much from their mistakes. Some people are just cut up about the whole forum thing at the moment but once it all blows over I'm hoping they will see the wisdom of working together.
And yeah, we will definately be our own entity. Keeping this fact in mind I can draw two conclusions.
1. We need our own forum & www, for obvious reasons
2. Since we have our own forum and www, we might as well have our own identity
At the end of the day mate I don't care if we call ourselves 'Skylines Seven Sins' as long as we have a club! :wink:
https://www.sau.com.au/forums/topic/81-sdu/#findComment-2155
Guest Impul 25T
Wise words.
Also remember, that it was mentioned quite a while ago that Aussie wanted to found a chapter, it was discussed and help was offered, but when push came to shove, nothing ended up happening. I really hope that some form of the club, wether it be SDU AU or whatever else, starts up in Aus and when it does, use the info that the kiwi based club members have. Like you said, they have been there, use the knowledge.
https://www.sau.com.au/forums/topic/81-sdu/#findComment-2156
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
