Hi,
I've got a R33 Series II GTST and is considering buying a hybrid cooler piping kit. I have read the installation manual on this site however I've realised that I have a windscreen spray bottle located in the bottom left hand side where the piping to the intake manifold is supposed to go. So to those guys with S2's and hybrid FMIC kits, how did you get around this? If not how did you set up your cooler piping??
Any help would be great.
Regards
Steve
G'day mate im pretty sure the plumbing goes over the radiator fan and under the water spray bottle, out the wall of the inside of the guard and then in to the outlet side of your cooler. Have you got a photo of your engine bay?? i have s2 aswell but yours may be diifferent for some reason maybe.
ive got a s2 and got my intercooler hybrid fitted on the weekend!
those instructions are not for a standard front bar if you look at the front page you will see what i mean....
that area was ok for me and a hole was made nothing in the way..
the only concerns i had was cutting my fan blades and as i have posted a thread
about this today my right pipe is bigger then the left one they dont look equal when looking at it front on view....
Hi,
I think I mite have to get a pic of my drivers side and the washer bottle... If anyone has a pic of there S2 and the hybrid kit installed, if you could please post a pic of the drivers side front piping it would be much appreciated. Thank you
Just checking to see if I've got mine on file. If so they will be up soon.
There was a bit of stuffing around required with an air saw, in the following areas:
holes in LH & RH guards
trimmed off/deleted lower mounting tag on washer bottle
trimmed off 10mm approx from fan blades
trimmed a lot of material on the std front bar girder (metal pressing that the outer bumper skin mounts to)
trimmed some material from the front bumper skin
deleted the std indicator assemblies from the bumper and did a bog/respray of the front bumper skin, used aftermarket LED indicators.
The whole job took lots of time and patience, but ended looking pretty good.
FWIW, mine is a S1, but the job should not be substantially different unless you have sourced an aftermarket bumper.
cheers
Hi,
I've taken a pic of the drivers side where the washer bottle is located but dont know how to upload it. I'll find out and post it but in the mean time, where the tow hook is located, that is approx. where the hole needs to be cut but I definitely have a washer bottle covering that area.
DaleFZ1, sounds like you mentioned something about cutting off the lower mounting tag of the washer bottle, so i think i mite have something similiar. I'll check your pics once their up.
The s2 sedan has the battery in the engine bay where our washer bottles are, anyway get a kit that runs back to standard ie pipes run back to left side. I installed this on mine and it works fine, the extra pipe didnt make much difference in lag or boost times
Hi,
Modr33s2, did you use a standard 180 Degree bend or did you have to modify this to fit? I've noticed that you have a standard front bar (in your pic)? Lastly, the piping that runs from the left hand side (looking front on) of the cooler, did you route that to the turbo pipe or inlet manifold pipe?
Anyways, thanks guys for your input..
I went from where they go through the engine bay, infront of left wheel and I used a 180 and 2x 90 to bring it back behind FMIC and up to engine bay( looks better than my crap paint skills) I did it this way so when I go to a gtr style plenum I can go through the engine bay off the 180
Hi,
Thanks Modr33s2... Ok I think I'll give it a try.. I also got a similiar setup but I "mitred" joined my 180 Deg bend so that I could go back behind the cooler without going in front of the front left wheel but I seem to be having some probs... I mite consider setup like yours.. looks better also. Thanks again.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
