There is a fair bit of info around on the forums about this. Do a search.
But in summary, a split pipe is heaps better, well worth the extra money.
See BATMBL's thread in the for sale section, has dyno graphs etc. He may be a bit biased (as he sells them), but it looks like there are significant gains in split vs just 3 inch dump pipes, possibly even 10kW or so.
Hey all,
Im making my own front pipe/dump pipe for an r34 (due to stupid prices from everyone) and am just wondering what the practical benifits of having a split pipe for the wastegate? Would it make much of a difference with a 3inch pipe coming off it?
Thanks!
Im pretty sure that they free up the flow of the exhaust gases as the standard ones are too restrictive for cars in seach of higher horse power. I think the split dump divides the wastegtae gases and exhaust gases for once again increased flow properties. can anybody confirm??
Thanks for the responses.
I was pretty sure i knew that the splits were better, less turbulence etc. Just wanted to know if anyone noticed this on our applications. At a guess, most people wouldnt venture far past 250rwkw.
Just weighing it up, its going to be alot harder to weld up a pipe with a split in it :thumbsup:
Thing is with the pipes you can buy, they are 300ish and upwards of that for split. That is just way to pricey for a bit of steel.
Wouldn't it be easier (and better) to weld 2 seperate pipes to the same flange from the turbo, then join the smaller seperate wastegate pipe into the main pipe later? SydneyKid suggests atleast 40mm.
Yeah, that seems to be the way to do it. Im just thinking about the flange, that could be hard. :P
get it laser cut. Thats how my mate did mine, and its pretty cheap to have shit laser cut ($50) or less.
Cheers. Ill look into that. Should be alot easier than me doing it :P
its internally wastegated. I plan to leave the stock turbo on it now, im not that power hungry, my missus still needs to drive it :)
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
