Finally after playing around with RB26 cams which i couldnt get to work, i installed the Poncams with good results.
Power went from 207 to 221kw both @ 18psi.
There is sooo much more top end its unreal, it just hits redline so much quicker, this is obvious in the graphs, where before power would drop quite dramatically it now holds a lot longer.
4500 165 172
4700 176 181
4900 183 189
5100 190 197
5300 196 207
5500 204 216
5700 207 220
5900 204 219
6100 201 217
6300 200 214
6500 192 210
Average Power = 192.5 203.8
If the first run continued to 7000rpm you would see an even bigger difference.
At first i was a bit dissapointed with the max power, but just lookin at how much more top end its gained im stoked.
Its off to the creek in a month or so ....
https://www.sau.com.au/forums/topic/81057-poncams-installed-221-rwkw-in-rb20/
What he said^^^^^^.
Interested on cam specs and what turbo is being used.
Nice result. Its not just top end thats improved it has gained power everywhere.
At 4,000rpm both setups are on par at approx. 100rwkw. But from then on the new setup is ahead on average 15rwkw all the way to 6500rpm and then gets better from there. I was always under the impression cams would sacrifice a little down low for the gains up top but this setup has proven me wrong. Do you have the boost graph from before? Because it even looks like boost is coming in earlier?
i would of thought that turbo would of made peak power even later than a stock turbs!
Is your power FC tuned for responce rather than peak power? Its very well known that the tune can change everythin!
18psi wit 170,000kms, motor must of been very well looked after mate :P
You still haven't told us what cams you are running. :P
Now you have done cams you will find a nice little manifold will help top end not to mention mid range. Possibly a HKS Cast item? They are cheap and flow well.
Excellent result.. Looks a lot like Roy's power curve.
Roy what cams were you running? :P
170,000km's.. Doesn't suprise me, The little old RB's are tough.
Interestering how peak rpm power stayed the same... :)
Did the cams come with the specs, intake opening closing etc?
Its a little sheet that should state something along the lines of IVO, IVC, EVO, EVC.
thats what i thought as well....
no specs sheet except for table on what other cams are available, like 260, 8.80mm lift ... however if you want to use those you have to go to solid lifters...
They set me back about $900.
And they are a straight bolt on, no shiming required...
Yeah, great result.
For the money spent, I reckon doing a cam swap for a set of Poncams is better value than doing the whole adjustable cam gear thing
I reckon this is what my car needs, just to get some more useable RPM out of it. Im sick of changing gears at 6500rpm! 8000rpm is what I want!
Cam also need better airflow to work properly.
Mine made no differnce in peak power, but average power was down. (Stock Turbo) but when I would in a touch more boost, look the fark out, because it took of like a rocket.
Just gotta get my higflow now!
Yeah, great result.
Standard cams should let you change round 7800 still?
Stock turbos dont help I guess.
Yeah, great result.
Forget about getting cam gears, even tho ive got these they made very little difference. They were tuned at 1deg advance on inlet 1deg retard on exhaust.
Thats when you know cams are well made, when they need very little to no adjustment to get the best results.
Save your money and get urself cams not cam gears !
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
