Nah, power noses over at about 6800.
From what I have seen and experienced the standard cams fall over at approx. 6,000rpm.
Although a lot of cars feel as though they are still pulling away strongly after 6k, mine included, a dyno graph will show power on the decline after that mark.
A good example is Troys RB20 who from memory makes peak power between 6-6.2krpm. But shifts far north of 7,000rpm on occasions.
Surely a much larger turbo would change the power band a bit?
Nope, only cam timing does this and duration and lift. I fitted a GT30 on my car and peak power is the same as it was when I had the standard t3 which means my car is acutually a lot slower down low now because now the cam timing events are still the same ie too early for the GT30.
Turbo provides airflow.
Cam timing determines when this airflow is most efficient.
If you fit big turbo, it will want will not change when the cams open at a certain rpm and thus you will still have peak power at the same rpm. This may not be the case however if your orginal turbo was really shit and couldnt provide enough air through the cams efficiency range.
Larger exhaust housings create less back pressure that improves top end VE. This in affect will help extend where peak power is made.
A good example is the rb20 turbo on the rb30det. lol.
Peak power is made by 4400rpm then goes flat and falls off rapidly after ~4900rpm.
The larger exhaust housings raise peak power to around 5800-6000rpm.
Back pressure = reversion.
The stock log manifold = back pressure + unequal reversion.
Which is why an equal length exhaust manifold is best for peak rpm power.
So realistically if you want to keep the stock log manifold keep the cam specs mild.
If you really want to extend your peak power you must not only do cams but also look at your exhaust manifold, ensure the turbo exhaust housing can handle the higher airflow at highrpm.
Possibly why Roy's power looks so awesome.
Nicely sized exhaust a/r equiv to .7 something from memory + a nice exhaust manifold. All he needs now is a nice set of cams. :P
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
