hey guys, i will be buying some new rims soon and will proberly go through tempe tyres, although i have heard a few bad reports,, also at the auto salon i checked out the tech9 tyres display and they seemed to have some good wheels, just wondering if anyone had delt with these guys ifso how did you find them, ifnot were did you go and what place do you recomend
cheers guys
https://www.sau.com.au/forums/topic/81081-place-for-rims/
while on the topic.. anyone know where to get Rays Engineering/Volk Racing Rims?
im chasing some Volk TE37's, and havent really found anyone that can get them...
http://page8.auctions.yahoo.co.jp/jp/auction/h27599948
buy now for $1670 + shipping
http://page11.auctions.yahoo.co.jp/jp/auct...ction/n18983611
24hrs to go current bid $870 (no bids on this item so far)
http://page7.auctions.yahoo.co.jp/jp/auction/g34403606
1day current bid $1240 (so far only 1 bid)
shipping is about $100 per wheel if u do by boat (take up to 6weeks to get it)
PLus buyer fees, bank fees, etc etc your looking atlest $600-$700 onto of the tottal cost
Just to give you an idea :), so you can compare if cheaper to buy in australia on overseas
https://www.sau.com.au/forums/topic/81081-place-for-rims/#findComment-1475666
guys take a look here http://www.nissansilvia.com/forums/index.p...showtopic=97642
As already mentioned, dont buy cheap nasty wheels when you can get some bargain priced excellent condtion lighweight jap rims very easily.
I bought some veilside andrews racing V (three piece rims) in 17x9 and 19x10 for less than 2K with rubber - the rims alone sell in japan for over 5k new. Before that I had ANZ 17x8x9 new with rubber (imitation 3 piece) and they cost me nearly $1000 dollars more.
We just dont have the market to get killer gear like the japs do - bit like the cars really :rofl:
Also, the C-red site is worth a look, they get some decent jap rims in too.
and some more http://www.nissansilvia.com/forums/index.p...c=82341&st=1140
https://www.sau.com.au/forums/topic/81081-place-for-rims/#findComment-1491681
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
