hey guys, i will be buying some new rims soon and will proberly go through tempe tyres, although i have heard a few bad reports,, also at the auto salon i checked out the tech9 tyres display and they seemed to have some good wheels, just wondering if anyone had delt with these guys ifso how did you find them, ifnot were did you go and what place do you recomend
cheers guys
https://www.sau.com.au/forums/topic/81081-place-for-rims/
while on the topic.. anyone know where to get Rays Engineering/Volk Racing Rims?
im chasing some Volk TE37's, and havent really found anyone that can get them...
http://page8.auctions.yahoo.co.jp/jp/auction/h27599948
buy now for $1670 + shipping
http://page11.auctions.yahoo.co.jp/jp/auct...ction/n18983611
24hrs to go current bid $870 (no bids on this item so far)
http://page7.auctions.yahoo.co.jp/jp/auction/g34403606
1day current bid $1240 (so far only 1 bid)
shipping is about $100 per wheel if u do by boat (take up to 6weeks to get it)
PLus buyer fees, bank fees, etc etc your looking atlest $600-$700 onto of the tottal cost
Just to give you an idea :), so you can compare if cheaper to buy in australia on overseas
https://www.sau.com.au/forums/topic/81081-place-for-rims/#findComment-1475666
guys take a look here http://www.nissansilvia.com/forums/index.p...showtopic=97642
As already mentioned, dont buy cheap nasty wheels when you can get some bargain priced excellent condtion lighweight jap rims very easily.
I bought some veilside andrews racing V (three piece rims) in 17x9 and 19x10 for less than 2K with rubber - the rims alone sell in japan for over 5k new. Before that I had ANZ 17x8x9 new with rubber (imitation 3 piece) and they cost me nearly $1000 dollars more.
We just dont have the market to get killer gear like the japs do - bit like the cars really :rofl:
Also, the C-red site is worth a look, they get some decent jap rims in too.
and some more http://www.nissansilvia.com/forums/index.p...c=82341&st=1140
https://www.sau.com.au/forums/topic/81081-place-for-rims/#findComment-1491681
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
