In two years of ownership, there have only been minor niggles, and the car has ALWAYS been drivable - it's never left me stranded on the side of the road.
The sorts of trouble I have had include:
- Power steering leak - busted hoses replaced
- Excessive front tyre wear - worn steering rack mounts replaced
- Suspension bushes cracking - replaced with polyurethane bushes
- Battery died - replaced
- Coil packs worn - soon to be replaced
- Misfire under load (after service) - spark plugs gapped incorrectly, repaired
- Boost guage failed - replaced cracked air hose
- Stereo speaker failed - replaced all speakers with new ones
- CD head unit failed - serves me right for fitting a crap one, replaced
- Aircon not very cold - windows lowered
So yeah nothing major has gone wrong. Stock boost however, which I'm sure has helped keep the engine in tip top shape.
Right now it has an intermittant problem where it won't start - the starter motor will turn the engine over, but it won't fire into life. Haven't had a chance to diagnose, but leaving battery on charge over night cures it temporarily, and you can always jump or push start the car. It might be a dead battery again - the car gets left undriven for weeks at a time due to work commitments, and that's usually enough to drain the battery so they wear out pretty quick for me.
Edited by Big Rizza
Ten months of ownership of a 1991 R32 GT-R. The car has been drivable ten weeks of that period. First engine - bad map, bad knock took out piston#6. Second (old, cheap worn out) engine, I drove the old, stock fuel pump into the ground by running 700cc injectors and 4~5bar fuel pressure. Det-based preignition during the pump failure took out all six piston rings in a meltdown. Now on it's third engine (completely rebuilt, refreshed, rebored, repistoned, re-bearinged, re-everything) which is making over 600bhp at the flywheel, but just lost its oil pump. In a highly tuned car, small mistakes end up causing BIG problems, and the vacuum lines are still not sorted out, causing a mysterious fuel pressure drop over 6000rpm. At this point (by my choice), the car is more "restored" than simply "repaired". I've spend USD40,000 on the project so far, and I am hoping mightily, praying actually, that the end is in sight and that I can just drive the damned thing. Expensive, but if all goes well, about $2-3000 more will see the car finished, and I'll have a car faster than a 911 turbo for a tiny fraction of the price (they cost about $250,000 in Korea).
I guess it just depends on how you look at it :)
Edited by kismetcapitan
hey all, i just now recently have joined your skyline groupy thing u got goin on here!
i just needed to reply to this topic as i too have had 6 commies and im only 20 years old!
i am meeting a guy wit a 1997 r33 to swap him for my vs ss, now my ss is in mint condition and has the works and the 33 had an exhaust and coola, but once again IT IS a 33.
do you think im doin the right thing????????
I flogged the living crap out of my R33 for ~2yrs, only thing that "broke" was the fuel pump, which was stock. All other "broke" things were self inflicted.
Although nearing the end I had nearly no third gear and there were funny noises coming from the bottom end, but that is what happens when you sit on the rpm limiter for that long, without letting it warm up either.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
