In two years of ownership, there have only been minor niggles, and the car has ALWAYS been drivable - it's never left me stranded on the side of the road.
The sorts of trouble I have had include:
- Power steering leak - busted hoses replaced
- Excessive front tyre wear - worn steering rack mounts replaced
- Suspension bushes cracking - replaced with polyurethane bushes
- Battery died - replaced
- Coil packs worn - soon to be replaced
- Misfire under load (after service) - spark plugs gapped incorrectly, repaired
- Boost guage failed - replaced cracked air hose
- Stereo speaker failed - replaced all speakers with new ones
- CD head unit failed - serves me right for fitting a crap one, replaced
- Aircon not very cold - windows lowered
So yeah nothing major has gone wrong. Stock boost however, which I'm sure has helped keep the engine in tip top shape.
Right now it has an intermittant problem where it won't start - the starter motor will turn the engine over, but it won't fire into life. Haven't had a chance to diagnose, but leaving battery on charge over night cures it temporarily, and you can always jump or push start the car. It might be a dead battery again - the car gets left undriven for weeks at a time due to work commitments, and that's usually enough to drain the battery so they wear out pretty quick for me.
Edited by Big Rizza
Ten months of ownership of a 1991 R32 GT-R. The car has been drivable ten weeks of that period. First engine - bad map, bad knock took out piston#6. Second (old, cheap worn out) engine, I drove the old, stock fuel pump into the ground by running 700cc injectors and 4~5bar fuel pressure. Det-based preignition during the pump failure took out all six piston rings in a meltdown. Now on it's third engine (completely rebuilt, refreshed, rebored, repistoned, re-bearinged, re-everything) which is making over 600bhp at the flywheel, but just lost its oil pump. In a highly tuned car, small mistakes end up causing BIG problems, and the vacuum lines are still not sorted out, causing a mysterious fuel pressure drop over 6000rpm. At this point (by my choice), the car is more "restored" than simply "repaired". I've spend USD40,000 on the project so far, and I am hoping mightily, praying actually, that the end is in sight and that I can just drive the damned thing. Expensive, but if all goes well, about $2-3000 more will see the car finished, and I'll have a car faster than a 911 turbo for a tiny fraction of the price (they cost about $250,000 in Korea).
I guess it just depends on how you look at it :)
Edited by kismetcapitan
hey all, i just now recently have joined your skyline groupy thing u got goin on here!
i just needed to reply to this topic as i too have had 6 commies and im only 20 years old!
i am meeting a guy wit a 1997 r33 to swap him for my vs ss, now my ss is in mint condition and has the works and the 33 had an exhaust and coola, but once again IT IS a 33.
do you think im doin the right thing????????
I flogged the living crap out of my R33 for ~2yrs, only thing that "broke" was the fuel pump, which was stock. All other "broke" things were self inflicted.
Although nearing the end I had nearly no third gear and there were funny noises coming from the bottom end, but that is what happens when you sit on the rpm limiter for that long, without letting it warm up either.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
