hay ppl
RB30 et turbo motor
balanced,blue printed. shot peened rods, re-bushed litle ends.
20 up ceramic coated pistons. crome molly rings
2mm copper head gasket
new rb25 water pump
intake manifold (turbo)and polished t/b
all sensors and reco injectors
recoed head ported +polished on the inlet side. crow h/d valve springs
3 angle valve cut.
Nispro stg 1 cam modified lifter housings. with cam sheets.
high mount extractors
had made 167 rwkw on 7 psi.
just run in had low oil presure so removed and put old engine in.
it was built for a replacement 4 original but had to revert back to it.
all machine work by port city engines in portland
$1500
thanks
https://www.sau.com.au/forums/topic/81108-rb30-et/
