hey guys just wondering what you guys have done for cold air induction?
has anyone boxed their pods to stop heat soaking?
ive just got myself a cold air pipe from my front bumper all the way up to where my stock intercooler pipes where for 30 bucks bent and fitted.. this was just from Mr muffler on kessels road..im looking to somehow box the hks pod to prevent heatsock and not get defected.. any ideas? :innocent:
cheers
vish
https://www.sau.com.au/forums/topic/81114-cold-air-induction/
I am keen to do the same thing as the heat soak is getting to be a problem on these cold mornings when stopped at lights. Confuses the hell out of the stock air flow meter! The tubing is a good start but I really need to get the cold air box made soon. I am going for a custom carbon fibre job from a guy in Geebung called Custom Carbon. Great guy and his ability with carbon fibre is amazing. Good prices too.
Any chance of some pictures to show what was done?
Dave
Personally, I can't see the point in having a pod filter if you're gonna box it up?
The reason you put the pod on is to increase air flow.
If you box it up you are reducing airflow to the size of inlet on the box/ induction pipe, are you not?
Would be better to keep the stock box with a high flow filter panel then wouldn't it?
or
a partition to keep direct heat might help???
Just my 2c,
The box is purely to keep the engine bay heat out. The piping from underneath is added to the inlet at the top-front of the box, just better positioned than the standard air box. Two inlets are better than one!!
well i have a mendral bent 3" pipe from my front left side corner bumper opening going up and boleting in place where the stock intercooler "elbow" was this brings in loads of cold air im thinking of getting a rubber panel to partition the pop & Airflow meter, this way it would get only cold air in no air from engine.. plus it wnt be defective .. i had a price done from hardcore performance they do the box setup for 120-150 fitted.. But they using just a simple flexible heatsheild ....
wat are the prices like for carbon boxs? ..
yes two holes are better than one!
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
