im just podering about something here guys, i hope you can help me out!
cold air makes your car go faster/more power...right? well, whats stoping me from rigging up the air con to cool the air going into the engine?
or am i missing something really obvious (which makes me look retarded)?
i know that it runs off the engine in the first place but it would chill the air well, and i would sacrafice 2% of power to get 10% more (as you know i just made up those figures!)
any input on this would be great!
https://www.sau.com.au/forums/topic/8112-air-con-mods/
Originally posted by tlai909
I don't think the law of thermodynamics works that way.
If you use 2% power to run the aircon, you'll only ever get 2% back by cooling at best (assuming 100% conversion efficiency).
Water spray the FMIC is the way to go.
T.
so making the air a lot cooler isnt going to make much diference then?
also...um, another dumb question...FMIC, intercooler? whats the FM for?
https://www.sau.com.au/forums/topic/8112-air-con-mods/#findComment-118113
Aluminium cools down very fast, the colour will make no diference.
Also, water sprays on the intercooler is pretty pointless. It makes no real noticable difference. Well thats my experience, and the tank emptys so quickly.
And the amount of power taken away by turning on the air con compresor is heaps, no matter how cool you get the air goin in you couldn't get that power back.
Just make a cold air intake with a section of tube leading in from behind a vent in the bumper up to the airfilter. If you have a fmic theres a seperate hole from the standard intercooler piping that is perfect.
https://www.sau.com.au/forums/topic/8112-air-con-mods/#findComment-118341
2% was just just a "ball park" figure...i guess my point is - if i could rig up something that the air con can run off an alternate power sorce, ie. batteries, would the performance be noticable, would it be a big gain or not much at all...im guessing it would be healthy for the engine aswell
https://www.sau.com.au/forums/topic/8112-air-con-mods/#findComment-118451
Hicks, im with you on the water spray. waste of time!!!!!!!!!
I hear a lot of ppl say the ac sucks power. I seriously dont hardly notice mine when its on. Surely there is some sort of clutch system? with a redline of 7000plus, does the ac compressor really spin this fast when you redline the car?!! Surely the thing disengages or something, as that would be too much compressing!! where would all the pressure go?
https://www.sau.com.au/forums/topic/8112-air-con-mods/#findComment-119085
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
