Guys,
I thought i'd run it by you all first. As of about 2 days ago my car started making funny noises/jolts when on boost.
Intermittantly, over about 4000rpm with foot on the go-fast pedal, the car would cough and splutter at various points in the rev range up until redline :)
almost like it's running out of fuel then finding it again. all intermittantly.....
do the symptoms described sound serious ? what could they be ?
TIA.
-Kym.
https://www.sau.com.au/forums/topic/8113-cough-engine-splutters-cough/
Puckish,
lets not go there again!
Kym,
It could just be a injector is clogged or fuel pressure is not constant. I'd first try some injector cleaner, this should remove any deposits. I would have thought if it was a fuel pump problem then Barry would have picked it up on the dyno, so try the simple things first.
Have you bothered to regap your plugs? What gap are they at and what boost are you running?
See'ya:burnout:
He didn't find my still-continuing bubbling noise on boost, so it wouldn't suprise me if there's more problems.
I haven't regapped the plugs yet, that's booked in for tomorrow garage-ala-kym! I'll see what the plugs look like too.. maybe they need replacing. If that doesn't work I'll pick up some injector cleaner too :)
I'm still on standard boost by the way, haven't had any higher than 7psi *sniff*sniff*
Thx for the advice mate :cool:
oh yeh, and nice to put a face to the name also Paul!
Kym,
Gapping the plugs is easy, I have mine at .7mm that way you can be sure of a good spark. It does sound like the plugs may need replacing, if you use octane booster alot then they definately will.
Hope it goes well, keep us informed.
See'ya:burnout:
Kym
Your car looked sweet last night by the way.....
Your problem sounds like spark plugs.... I think they are ROOTED.... if you are running standard boost (7 psi) you do NOT have to regap them .... but it is advisable....
I dont think the problem is the gap.. i think they just might be stuffed....
if you use ocate booster they stuff really screws up your plugs......
just hope its not your coils ... they are a tendency for going shit on the RB motors......
Good luck Kym
Daniel
Originally posted by IMACUL8
Kym
Thanks buddy. LOVED your car too btw :) nice sounding BOV too... luvin it *drool*
After some body mods it'll look alot better (read: ultra-wide GTR wing, some skirts, and a S2 front bar (for FMIC))
Okay, so i'll be replacing the plugs tomorrow. That should help. I'll let you know how it all goes then :cool:
  • 2 years later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
