You should probably replace it since it's already torn down. Might as well buy a metal headgasket.
Sounds good in theory but a thicker head gasket is definately noticable when driving off boost.
What mods do you have? If you're not planning on big power, I would suggest replacing it with a standard Nissan gasket.
Don't reuse the existing one, you might as well swap it whilst it's out
https://www.sau.com.au/forums/topic/81136-head-gasket/#findComment-1474579
I guess I just assumed because if he's not increasing the power, I can't see much point in getting a standard thickness metal head gasket :confused:
How do we know he's not increasing the power? :confused: hahaha It's whatever you wanna do. Personally I would've replaced it with something stronger. You might not want more power now, but a few months down the road you could. Better to replace it now than have to tear it apart again. You don't have to get a thicker headgasket to make power. Compression = Power & Response
https://www.sau.com.au/forums/topic/81136-head-gasket/#findComment-1474691
uuum i have a aftermarket head gasket and its the same thickness as my standard one in my r34 and the engine is good for 600hp...keep the same compression is good no lag and very rev happy. u dont have to go to a thicker head gasket if u want to modify your car for more power.....
https://www.sau.com.au/forums/topic/81136-head-gasket/#findComment-1474815
well I have used the standard rb26 with o ringing and have had cars making over 600hp at the wheels without a single problem.... The standard ones are quite good but something like a stock thickness cometic or jap brand one will probably help you sleep a little easier at night if you dont o ring it that is!!!! CHeers
https://www.sau.com.au/forums/topic/81136-head-gasket/#findComment-1474839
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
