Sniffy,
You can use the factory throttle body, but it is quite restrictive and you need to make an adapter plate. The Infiniti just bolts straight on, cost around $400, 85mm diameter. If the shop knows what its doing then about three hours to swap plenums, takes longer to add FMIC and piping.
See'ya:burnout:
squizz - how many GTR's do you see with aftermarket plenums? Bugger all. Youve already got a plenum that allows easy fmic plumbing, probably a waste of money at this stage. spend it on the pistons and you wont have to worry about them again.
get in irc more fool.
Ɨ
Ɨ
