Hey guys/girls,
Just a quick question - sometimes when coming out of a corner hard in first gear, the LSD won't lock up and will only spin one wheel. However, as soon as I put it into second gear, both wheels start spinning and sideways it goes.
It's weird though, sometimes it does lock up fine, but most of the time it won't, mainly noticable in the wet...
Is there any reason for this? Is that the way stock GTS-T diffs are built, or? Will change the diff oil help this? Or is the LSD simply getting worn out? I find it weird that it always works perfect in second gear, leading me to think they are designed like this? Everytime i've done a burnout at the drags, both wheels lock up fine...
Any advice would be great.
Thanks,
Tommo.
has it always done this? or only just started happening
I'd say your stocko viscous lsd is probably just worn out. Try doing donuts in 1st gear, and see if you can keep the end out. Stock viscous in good nick should be able to keep it going, a worn one will crap out and single spin.
I've never really been giving it much before, especially around corners!! However now i've learnt to drive RWD beyond the limit, I've been testing things out, thats when I noticed it won't be locking up in first.
Merlin, that's gotta be the best excuse for doing heli's i've ever seen in my life :D I'll try doing a few quiet ones this weekend and see what happens. I'll defintely look at changing my diff oil anyway, as far as I know it's never been done before (since i've owned it, anyway)
I'd say your best bet would be to change your diff oil. Motul pa 90 is quite good for diffs, and at 20$ for a tin, you can't go wrong. it'll save you so much stress thinking about whether your diff is warn out etc.
It is very easy to change as well.
When I got my car and changed the oil, the previous owner must have never changed it, because it was black and so thick it was almost solid. Required a good two changes before the oil was clear. Lets just say that afterwards, I was smiling. :D
  TommO said:
Merlin, that's gotta be the best excuse for doing heli's i've ever seen in my life :)
oh hell yeah! we have our own designated "diff testing area" we use to test diffs to see if they are worn or need reshimming when testing a car for drift-worthiness... if you can't do proper donuts, your diff isn't locking well enough!!
Sweet, i'll head up to Unique and buy some on Friday... I want to get my gearbox oil done at the same time, sounds like a good excuse to me :):):)
Gotta love how the diff is on the way out with only a claimed 56,000kms.. damn jap cars and their false odometer readings :D
Hey mate,
I ended using the relavant redline oils for my diff and gearbox.
Gearbox is BEAUTIFUL, makes it very very nice to drive with :D I'd recommend it to anyone, even if your gearbox feels fine :)
Diff is also much better, but not as noticable as the gearbox.
Either way, for a couple of hundred bucks, it's a pretty cool upgrade :):):)
Cheers,
Tommo.
Defintely made it better, if i'm not turning too much in first it'll defintely hook up.
But if I come out of a corner in first at 45 degrees to the road, it'll generally spin one wheel until I go into second gear.
I haven't tried helis yet.
  the97skyline said:
Hey Guys
I have changed the oil in my diff as well to the redline stuff a while ago and the single thing in first still happens. I think its time fir a reco.
My diff is very similar however it will only light up the rear right, extremely noticeble in the wet, if I flog it around a right hand corner the ass kicks out and the right goes nuts. If I do it around a left hand corner then the rear right still lights up but its sketchy but doesnt really let go. In the wet even small overtaking/turning makes it light up.
Damn pos stock LSDs.
This is in a HR31 as well. Time for a mechanical LSD I think.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
