  • Replies 68
And the winna (so far) is B-Man @ $68,600
Car - $21K
First Batch of mods - $13K (FMIC, Hi Flow turbo, Injectors, ECU, Tune, Front/Dump, cat, etc)
Blown Motor
Second Batch of Mods - Engine Rebuild $20K (included new everything - bulletproof)
New Turbo & manifold - $3K
New ECU $1400
Greddy Plennum - $1.2K
Buddy Club Wheels - $2K
TIEN Suspension - $1.2K
Clutch - $650
New Springs - $450
Oil Cooler, Thermostat, lines - $1K
Bigger FMIC - $1600
Sound System $1K
Semi Slicks - $1100
Terrific waste of money :P
Al - You are just gonna have to trust me - I have all the receipts, too many of them to scan in.
Anyone who knows me and my old car (NSW SAU) can vouch....
Pity I don't have the car any more....
Car - $21K
Blown Motor
Semi Slicks - $1100
etc.....
There are these things called a V-Spec :(, sounds tough though.
Purchase $16,500
Mods $8,500
& still has stock wheels, kit & no stereo system :rofl:.
1998 R34 GTT
Purchase Price: $28,000.00
TEIN HA Coilovers + Xenons: $700.00
K&N Panel Filter: $120.00
Trust Cat Back Exhaust: $300.00
Boost Gauge: $25.00
Boost Controller: $35.00 (from SAU)
Turbo Timer: $129.00
HID Parkers: $20.00
RICE GEAR: $20.00
Total so far: $29,500.00 approx.
Only had the car for 1 month :D
NOTE: Someone mentioned women before; take it from me, these cars get in the way of women and yourself. My girlfriend is way way jealous!
R32 gtst 4door $13000
Onroads $2200
Alarm $550
Replace lhs indicator $85
Major service timing belt, O2 sensor, inj clean $650
Oil pressure sender $200
Fresh gearknob $45
Tomei 300kph speedo $275del.
R34GTT rims W/ new tyres $650
Respray rims Gunmetal $400
Hybrid FMIC $320 del.
Custom piping, hoses, clamps etc $400
Strut brace eBay bargain $37 del.
N1 bar ducts $80 del.
Respray front bar $300
Fujitsubo powergetter $850 del.
R33 brakes and seal kit $300
RB74 pads $130
Power fc $1420
Bosch 040 $240 del.
Split fire coils $640
Iridium plugs $99 $22871 plus $8K stereo
Hell, I hope my wife doesn't see this.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
