You'll need the pinout diagrams for both the current engine and the new engine as a minimum. wiring diagram for the sr will help but isn't essencial as you can trace everything you need with the pinouts.
An SR engine crossmember, engine, gearbox and loom/ecu would probably help.
RB g/box crossmember can be modded to suit, same with an sr crossmember.
Tailshaft may need modification, though i dont know for sure. SR shaft has the right splines and diff flange though.
couple of adapters for the heater hoses and some custom pipework for inlet/intercooler piping and a modded front pipe.
Thats about it, it's a pretty easy swap.
https://www.sau.com.au/forums/topic/81168-sr20det-into-r32/#findComment-1475217
don't do it.
it will endup costing like 5g to get it done, and although the car will be very well balanced for drift,
If you spent the same money on castor rods, good bushes, swaybars and coilovers. the car will handle perfectly for drift.
+ RB20s are great little drift engines!!!
just add cams, and an 2530 and you have got 200rwkw and 8000rpm of reving power!!!
https://www.sau.com.au/forums/topic/81168-sr20det-into-r32/#findComment-1475245
correct me if im wrong..but wouldnt it throw off the weight balance as your putting a lighter motor in the front end, an sr being a shorter motor and all alloy... How does it sit over the front end in comparison to the rb?
https://www.sau.com.au/forums/topic/81168-sr20det-into-r32/#findComment-1475311
People in Japan do this conversion in R32's and Cefiro's as the RB20 has a big torque hole down low. However for what the conversion will cost I would suggest just working the RB20 and getting good suspension etc. As already said, a GT2530 will cure the torque problem and make the engine very Drift friendly.
https://www.sau.com.au/forums/topic/81168-sr20det-into-r32/#findComment-1475335
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
