Hey
I just installed a front mount intercooler and ihave notice the pipe that goes along side the engine to the drivers side gets very warm. I am thinking of puttting heat wrap on it (the fibreglass sorta rope stuff that you put to heat wrap exhausts) would this be a good idea or is there something better i could you?
Also there was a crack in on of the pipe and i have put a bit of silcon pipe over it with hose clamps will that do the job??
thanks
Anton
https://www.sau.com.au/forums/topic/81191-heat-wrap-on-cooler-piping/
Hey
thanks
Anton
To lock the heat in to keep it out? with that shit on there its just gona get hotter n hotter... its designed to keep heat contained.... thats why you wrap your dump etc to prevent the high temp of the metal from heat soaking the rest ov your engine. if you realy wana get rid of this problem id get a vented bonnet so cold air is blowing onto your pluming. but thats just me
not the brightest question but now you kno
I put the heat wrap on my cooler piping to find that it works very well, the cooler pipe on top of the engine is almost as cold as the cooler itself. Were as before it was warm/hot. but i have read in other threads that the air passes through too quick to even collect heat, try it yourself and see, cost you around $50
yeah i figure yeah its made to keep the heat in but there isn't any heat realy being created in the pipes however there is heat in the engine bay and that is deferntly heating up the pipe as it gets quiet warm when i have felt the pipe.So the heat wrap should stop the heat in the engine bay entering the pipes
I currently have some insulation tape for sale: http://www.skylinesaustralia.com/forums/sh...ead.php?t=80672
I found that stuff to be pretty good. I found that after a drive, my engine bay was very hot. The piping, especially the one that crosses over the engine was too hot to touch after a spirited drive.
It worked well. Just as a test, after a spirited drive. I took the crossover pipe off to change the spark plugs. The inside of the pipe was only slightly warm, which I suspect was from the air which had been warmed due to compression by the turbo.
Another added benefit, is it gives my car a race look and also covered up ugly rusty pipes.
depends where the vents are IMO. Engine bays are not tight like a V8 so its less crucial.
But as for wrapping. The air is moving at such a rate of knots that i would highly doubt the air would increase "that" much in temp anyhow
I think Sydney Kid has said this many times.
The air that goes from the cooler to the inlet manifold passes through that pipe at such speed that it doesn't have time to pick up heat from the pipe.
He has tested this with many temp probes I believe.
I think he said at one point they had 3 temp probes.
1 in the intercooler pipe just outside the turbo, one after the intercooler and one before the throttle.
I think the temp increase from the cooler outlet and the throttle body was tiny.
I'd save my money or spend it on something else..
u will find there is little difference with the tape at 5000 rpm on 7 psi boost, u are using approx. 12500 litres of air per minute (5000rpm/2(4 stroke)*2.5(L)*2(boost)). Say you cooler piping is 5m long, and 8cm in diameter, the volume of cooler piping is 25132 cc or 251.32 litres, therefore the air is flowing through pretty fast. The air in the pipe is 'refreshed' 1000 times per minute or 16 times a second, not much time for heat absorbtion.............
I run a inlet air temp probe in the crossover pipe above the cam cover, and have also spent reasonable time working out the dynamics of heat absorption in the inlet piping.
Main problem for heat soak occurs at low speeds (stop-start traffic conditions), and when running at consistently low throttle openings at low-moderate speeds (= low air flow). The major source of heat transfer is the hot air (@80 deg C) exiting the radiator onto the piping running across between engine and radiator (assuming you have that sort of setup), and secondly the heat rising from the engine itself.
Once you are moving constantly over 80km/h, and/or running reasonable throttle settings, the whole system starts to work as designed, and you can see the temp reading dropping from about +30 deg over ambient to about +10deg over ambient.
The lesson is in understanding how/why your car performs as it does if you engage in a run at the traffic lights.
Insulation of my pipes did show a noticeable reduction of temp differential, to the extent of about 6-8 deg vs uninsulated. Most noticeable though was the difference in the rate of increase (takes longer to hit the max delta), and significant reduction in the whistling noises generated in the aluminium piping.
For me, the noise cut was the biggest improvement from applying insulation.
cheers
I'm not commenting on weather this is effective or not but I thought I'd just mention that the tape I have seen does not work one way as well as the other, it's just the way it's designed (to keep heat IN).
If you want to use it on your cooler pipes, use it the opposite way than which it is designed to be used, this way you're keeping the "heat in" to the outside of the pipe, i.e. away from the pipe.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
