I want to know if I change my springs to something a little bit softer will the harshness of my ride improve or is that mostly dependant on the shocks. I have JIC in there at the moment but I dont know what the spring rate is in them.
I dont know if I should buy a whole new suspension, or just change the springs to somehting softer????
I just dont seem to get any travel in the car.
Cheers
do you have an adjustable coilover suspension? i know its obvious but try putting it on the softest settings... i got JIC coilovers as well but cos it came with the car and its got no model number on it i just turned the knob max to one side and the other and tried to feel the difference...
either way coilovers are generally uncomfortable on normal roads so if you do lot of travelling maybe you should look at getting normal suspension for everyday driving...
nup only hieght adjustment, I had tein in my 32 but they were nothing like this, I just wanted to see if a lesser spring rate would soften the ride and increase the travel. Its rather ridiculous at the moment the hardness of the ride. cant hit bumps, pot holes or anything without a massive thud.
Softer springs will help, but the valving of the shocks (how they handle bump and rebound) will also affect the ride.
I just put lowered springs in my R30, and because the shaft of the shock now sits further into the shocker body, it has totally changed the ride characteristics (quite harsh now). Same when I lowered the 32 on standard shocks.
The shock doesn't care whereabouts in its travel it sits, the valving is the same. The usual problems are;
Did you trim the bump stops?
If you left them the standard thickness then (if it is lowered too much) it will be slamming into the bump stops.
How much travel does it have?
How do you tell how much travel it has? The best method is to place a cable tie tightly on the shock shaft, quick drive around then check where the cable tie is pushed up to.
What are the rates of the springs you put in?
There is a thread on this section where I show you how to measure up your springs, post the dimensions and I will work out your spring rate for you.
More than 50% of the harshness in Jap coil over kits is due to their rediculously high spring rates. Most times when I have changed (or recommended a change in) spring rates, the guys report good/satisfactory results. A common trick is to put the rear springs in the front and buy some softer (around 200 lbs per inch) rear springs. That's a cheap fix at under $200 if you do the labour yourself.
If you want to know what the current spring rates are, pop over to the thread in this section (How do I know what my spring rates are?).
That's OK if you have X-ray vision to see through the rubber boots. (Do I really need them?)
:D
They are Pedders HD lowered springs. I originally had their "standard height" HD springs. I was going to post on your thread, but when I measured them up, I found that both sets would be identical (same wire diameter, same coil diameter, same active coils, just wound to less free length).
That being the case, why is the ride, on a relatively smooth main road, so much harsher - it can't possibly be sitting on the bump-stops.
Ok well measure the springs only on the front
OD. 80mm
thickness. 11mm
no of turns. 8
This doesnt seems to be too bad as compared to others on the thread where you were measuring rates.
I also did the cable tie trick and found that the travel is only about half way up the shaft. Normal???
I usually just push the rubber boot up, slip the cable tie on, pull it tight and go for a drive, hit some of my regulars pot holes (always plenty around my area). Then slip the boot up again and see where the cable tie has been pushed to.
The rubber boots keep dirt out and stop the seals (on the top of the shocks) from wearing out from the grit.
It has been my experience that 9 out of 10 times (when fitting lowered coils) I have to trim the bump stops. If that wasn't done it is highly likely that some premature bump stop contact is occuring.
I would always take it back to Pedders if I wasn't happy and ask them.:(
Solved half the problem - the springs were in UPSIDE DOWN. They are wound tighter at one end, and that end has to be the top. So, pulled the out, flipped them - feels a bit better now. I've got the cable tie on there, will check it later.
  • 3 weeks later...
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
