Yeah guyz,my mate had some mods done to his r32 gtst sedan and was put on the dyno for comparison.first power run with only k&n pod,exhaust from cat back 3inch,standard boost which was 11psi got 147rwhp.after fitting the cooler that figure went to 166rwhp then when 15psi was bled into it 210rwhp with the standard computer was netted.all air fuel was fine.basically no tuning has been performed.can any of you guyz tell us how much more power an apexi computer would give us.anyway let us know if that is a reasonable figure for these mods.thanx....
https://www.sau.com.au/forums/topic/81197-210rwhp-rb20-with-these-mods/
that is a great figure is he running the standard turbo if he is it isn't going to last to long i wouldn't think pushing out that sort of psi. i have.
GT30 ballbearing
pod
fmic
3" turbo back exhaust
500cc injectors
fuel reg
wolf 3D
45mm external waste gate
i got 210rwkw not sure what that is in horse power think around 300 don't know anyone now
just to make things easier 210hp is 156.6kw
I make 148rwkw or something like that with exhaust, fmic, s-afc2, fuel pump running 12psi of boost (0.8bar). Tuning will give you probably an increase of around 10-20rwkw top end but will make the car more responsive allround.
Make sure you get a bigger fuel pump before you do so.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
