147rwhp with 3 inch cat back,k&n pod filter,standard boost,which was 11psi???.after fitting x-force front mount intercooler,the power went to 166rwhp,then we put 15psi through the standard turbo and got 210rwhp.the car is an auto.let us know what you think as any advice would be appreciated.
https://www.sau.com.au/forums/topic/81203-r32-gtst-sedan-dyno-today/
147rwhp or 147 rwkw - 147 hp seems low, and but 147 kw would be closer.
11 psi isnt normally stock - 7=8psi is normal
15 psi is asking for a blown turbo.
What engine management are you using?
standard computer,what turbo do you suggest that will bolt directly in place that will handle the 15psi and all power figures are in rwhp.we actually thoght that it was kw but is hp.anyway the car is a true sleeper.
I wont advise on the turbo choice because I am not as familiar with the RB20 as I am with the RB25s. Search the threads and I think you will find lots of help.
You may/will also need to consider upgrading your:
Fuel Pump, Injectors, Engine management (but I think you can reprogram the EPROM on a 32 which is cheaper) and turbo to push more than 200rwkw reliably.
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
