Hey,
I recently installed a Power FC into my R33 S1.
other mods include FMIC 3 inch straight through from turbo
12 psi and pod.
When I first took it to my tuner to install and tune the Power FC it had a major problem with a major miss fire as soon as you put your foot down at standard boost using the standard ecu.
after replacing the spark plugs with a new set of NGK standard 0.7mm gap it fixed the problem. So he went ahead with the install and tuned it over a 4 hour period on the dyno.
My problem after that though is that as soon as you put your foot down now it kind of stutters a bit as it hits max boost before I get power. It is like there is nothing there for a second then it comes on again.
I tried re gapping the plugs - first to 0.9 mm which made it go back to having the original backfiring issue as well as this new problem. Then I tried re gapping the plugs to 0.6mm which just got rid of the misfiring issue still leaving me with the stutter for want of a better description.
Does anyone have any ideas / suggestions of what my problem could be?
Could the coil packs cause this issue?
If anyone could help I would really appreciate it.
Thanks
had exactly same problem. it was my afm changed it with a z32 no more problems.. and on the way i changed my fuel pump/filter & sparkies vthen i got it tuned and it was perfect ;)
AFM?
wouldn't have thought that the AFM would have made that much difference.
but will give anything a go to fix the problem.
Thanks
So you tested it after the installation of the Z32 AFM and it fixed the problem?
or did you only test it after you changed the fuel pump/filter & sparkies as well?
If you have had to gap the plugs down to 0.6mm (that's only slightly more than HALF the design spec of 1.1mm!) then you have a serious problem in the ignition department.
It's possible the acceleration enrichment needs some work as well.
The standard NGK plugs come out with a 0.7mm gap in them, so I only reduced it to 0.6 as the tuner suggested.
as for the acceleration enrichment, I checked my figures against another forum members and we had the same figures
Acceler.
5000 5.2 2.0
4000 4.8 1.8
3000 4.2 1.5
2000 3.4 1.1
1000 2.4 0.6
Water temp. Corrections.
+80 1.00 1.00
+50 1.09 1.15
+30 1.14 1.29
+10 1.25 1.50
-10 1.39 1.73
-30 1.29 2.00
do these seem right?
have borrowed some coil packs for the weekend, will try to replace my packs one at a time to see if I have dodgy packs.
The tuner thought this might be the case as he said I actually was low on power from what he was expecting, and thought this might be the problem.
does this sound plausible to anyone?
I had the exact same problem, misfire after installing 3" ex fmic and pod filter.
turned out to be coilpacks, splitfires went in and fixed it up good now I run 0.9 gap and spark is strong right through.
my miss was more prevailant at higher revs but was hesitating from 3000 revs up most the time.
Acceler.
5000 5.2 2.0
4000 4.8 1.8
3000 4.2 1.5
2000 3.4 1.1
1000 2.4 0.6
+80 1.00 1.00
+50 1.09 1.15
+30 1.14 1.29
+10 1.25 1.50
-10 1.39 1.73
-30 1.29 2.00
That's the standard (default) PFC settings, acceleration enrichment HAS NOT been tuned. Take it back and ask for it to be tuned properly.:(
PS; It has been my experience that 99% of the time when people blaim coil packs it's something else. Usually poor tuning.
Does anyone know how to tell if a coil pack is stuffed?
with leads it is as easy as testing the resistivity with a multimeter.
But how do you tell if a coil pack is ok?
I have got a hold of another set of coils to replace my original stuffed coils ( to test if that is the problem) and I need to know if there is a way for me to tell which ones to replace.
Thanks
You can tell if a car is misfiring on a dyno as the mixtures will go lean, unless you are running a fuel that carries its own oxygen like C16. It actually sounds like an AFM problem though. What type of pod filters do you have as a few brands will actually break off and lodge on the sensor which will give you the symptoms you are describing. Would also like to know who did the tune.
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
