Greetings All.
It also depeds on what type of vehicle you are trying tp build...Streeter...Dayly Driver/Weekend Warrior...Track demon, but still docile enough for street driving...
Also what do you expect from your turbo?? Put your fut down at ANY RPM and be pushed back into the seat...or an on/off style power delivery...?
Cheers,
--Tonba
108rwkw with 3inch cat back and a FMIC?
that sounds pretty 5hit house man
my ageing 88 model redtop rb20 made 116rwkw with 3inch exhaust and pod. the rest was stock
i was at the understanding that most silvertops will making that much (110-118rwkw) in bog stock trim.
have u had your compression checkd on your engine?
Matt
Yer the car was a bit sick it was the tune when i got 108rwkw after i had it tuned i put a pod and BOV on i guess it all helps a little we got 138rwkw with standard standard everything else which i thought was good. Then the standard turbo sh8t it self hense why i have done all this work to the car. Well i drive the car every day so i guess i wouldn't wont to much for power i guess but you know what they say a person that has power always wants more hehehe. I don't mind the turbo coming on late although i wouldn't mind it coming on about 3500 instead of the 4200, the guy that gave me the turbo says that it has the smallest exhuast housing on it which if i am not mistaken helps boost earily not sure guys
your next step maybe should be porting of the head, and some cams ~$2k or so.
Signs point to that turbo not being a full '650hp' turbo - but hey.. why bother with internals when you can squeeze a bit more out, and keep going until you have reason to bother with internals.
You might get another 10-30rwkw (~235rwkw), which might be the real level of that turbo. Thats a good amount of power from a RB20det.
thanks guys this is helping a far bit and giving me a lot of options. The guy that tuned my car at rank rotory said the same thing about the fuel pumps they told me that i should be able to get maybe another 10 - 20% out of it as i will be able to turn the fuel presure up a little. I really am trying to get to that 250rwkw mark not sure if i will get there what will i need to get into the 12's for the 1/4 mile i am going next month to see what can get with what i have now.
Greetings All.
Some things you might want to consider before cracking open the block for a rebuild...
  • Port & Polished Head
  • Adjustable Cam Gears
  • Extrude Honed Exhaust Manafold
  • Larger TB with a Z32 Airflow Meter (Better for tuning)
But before you do any of these a GTR fuel pump might be the go...
My 2c,
--Tonba
That would involve removing the head, so new head gasket, plus labour etc. Much nicer solution would be to just throw some cams in. The cost of remove and install head, head gasket, porting and polishing etc would be a lot more...and drama being that the std cams could be the limiter, more then the ports when std????
If he is still running the std manifold with a 45mm external wastegate...then id say dont bother extrude honing it, again the cost in labour to remove and install plus extrude honing would be better spent on getting a good quality / deisng manifold. But im assuming since he is already running the external gate he has the manifold side of things sorted.
He is running a Wolf 3D so would be amazed if he was still running an AFM...though the larger TB could be an interesting thing to try because i have often wondered what if any is to be gained.
And sorry not meaning to be picky, but i wouldnt even go for a GTR fuel pump, for the same money or even less you can get a Bosch 040 which is new and flows more and is easy to fit....just another opinion:)
i was thinking of buying a walbro i can get one of here from happypig i think he goes by for $165 would this be ok. I am not running a AFM i just have a 3" piping from the pod. What would i be looking at in gaining with a set of cams in terms of rwkw and cost involed in this sort of operation
hey guys it seems that my car isn't running on the 16psi i thought it was it turns out that it is on;t running on about 12 as i founf out last night well thats all my boost gauge would go up to would this be correct in making this sort of power with this boost. I thought they tuned it to 16 but it turns out they didn't they said they would turn it up to 16 with a bigger fuel pump i guess then i will get my extra 30 - 40 rwkw
i say run it on another dyno 729NM doesnt sound right with that kw figure
other than that get some new cam gears (mayb a step bigger cams), extrude hone what ever you can afford to (even you turbo if you want) and most definetly upgrade your fuel pump man. Probally a good idea to get the Z32 afm too.
The most important step however is giving your car a good tune!!
i have had a few people say that to me about the 729nm i am going to get the fuel pump and tune again then run it on 2 different dyno's see what the difference is, i am not running a AFM i am running wolf 3D so i have taken it of and put all new 3" piping in
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
