  • Replies 83
any chance of thermostats yet?... or can you direct us where to get one that will siut the kit>?
Hi mate, the kits do no include a thermostat, however as with the majority of other kits available on the market you may be able to add one.
We have been using them for a long time with customers in Australia and abroad without any problems at all.
Currently they are in use on everything from fully prepped Targa race cars to highly tuned street GTR's.
Realistically, you should not have any issues whatsoever running our oil cooler kit without a thermostat.
Regards,
Steve
do you sell just the oil cooler? i've bent mine so only need the cooler.
Hi mate, yes we do.
We can provide you with a 19 row oil cooler for $89 delivered and you can place your order online via our website using the URL below:
http://www.justjap.com/oilcoolerspecial.htm
Cheers,
Steve
Hi mate, yes we do.
Cheers,
Steve
sounds good! just one question, what are the dimensions of the core and size of the fittings?
Edited by kwazza11
Please give Darron a call in store on (02) 9545 0532 and he can measure the fitting size for you as im in Japan at the moment.
Cheers,
Steve
Cheers,
Steve
Meh, too late i ordered it anyways... ;) nothing a couple 90 degree adapters wont fix.
thanks Steve.
stay away from the Saki!
Meh, too late i ordered it anyways... :D nothing a couple 90 degree adapters wont fix.
thanks Steve.
I'll do my best :D
Plenty of these kits left in stock - Thank you to all of you who have ordered
Cheers,
Steve
  • 3 weeks later...
More stock has now arrived, keep the orders coming guys.
Order online now for speedy delivery Australia wide
http://www.justjap.com/forumoilcoolerkitspecial.htm
Cheers,
Steve
Cheers,
Steve
Do you have a Oil Cooler & Filter Relocation Kit to Suit Nissan R33 RB25 in stock ??
We certainly do, and you can order online at the special forum price via our website using the URL below:
Cheers,
Steve
Thanks for all the orders - we have loads of stock available in our Sydney warehouse.
Cheers,
Steve
Ill be able to pick it up
Do you have the thread size for the fittings available please? To save me a trip to have a look
Steve, I have dropped you a pm.
We are frantic getting the GTR's ready for Targa but if you give Tony or Darron a call in the store they can confirm the sizes for you.
Cheers,
Steve Thatcher
Thanks for all the orders guys, this offer is still available and we have plenty more stock ready for immediate dispatch and pickup form our Sydney superstore.
You can order online via our website using the URL below, or drop by and pickup your kit over the counter
Cheers,
Steve
  • 1 month later...
Hey, want one for my R32 GTR
where abouts do most people install it? in the RH front bar air duct?
anyone got pictures of the install?
also how much extra oil capacity will there be with the relocator kit?
mark.
Edited by markimak
mark.
Hi Mark, thanks for your enquiry.
Most of our customers have installed these on the radiatiator support behind the front grill.
In terms of extra oil capacity, I would say a bit under .5 litres at a guess.
Regards,
Steve
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
