Why is my car holding back?
leb
 Share
Hey all,
The other night (private roads of course) I was pushing my car (s14)
I noticed that in 3rd gear at 5k rpm it sempt to no longer really accelerate.
It sempt like it wouldnt go any faster, what could this be?
note: car is stock therefore boost problems shouldnt really be existent.
Is there anything that I can do to make it more efficient at higher engine speeds?
Dee 33 It kind of felt like the extra revs werent giving any power. It was sitting at 5k rpm (and wouldnt go any higher) going up a hill at 140 in 3rd gear, so MAYBE it was to do with the slope.
I didn't put it in 4th because there wasnt enough room to safely slow down
Its the local 200sx s14, not the jap one
Abo bob Yep, the whole car is stock - I dont know whether to do it up (with and exhuast and boost controller) as it costs $$$$ to do properly.
Is it worth chucking on a 3inch turbo back? and getting an electronic boost controller?
i had this problem in my car a while back(s13) but it was in several gears...
i changed the clutch, cleaned the pod filter works fine....
if it only happens at a certain speed..then its prolly a limiteror other reason
breathing and boost restrictions usually happen at the same rmp, through different gears
I was testing my newly arrived R32 GTR the other night, also on private roads by chance(maybe we were on the same road ;) )
I had no such problems thats for sure, 3rd revved out nicely, as did 4th. Come to think of it, I think 5th gave a good showing as well. What limiter?
What kind of hill are we talking about? A slight rise, or a mountain pass? You could just be at the limit of your cars pulling capabilities.
With regards to the mods to your car, they are two of the best mods you can do to any turbo car. Have a look around, you'll be able to find plenty of suppliers on the forums, both local and importers to provide such mods.
the problem is you only got a 2 litre donk...... nah just kidding,
give the car some good tlc and eliminate the obvious things off your list like, oil change, clean pod filter etc etc..... once the simple things have been checked and it's still giving you problems, then it's time to head to a mechanic, unless your mechanically inclined....
thats what i would be guessing, aren't sr20's low revving engines? I haven't driven many, but thats what i'm thinking
i'd say if you wanted it be pulling still at those revs then you should've bought a skyline, feel free to correct me if i'm wrong though
my thoughts: if it's a stock car you probably just ran out of breath - swap the exhaust at least and the filter for a high flow panel or a pod? how steep was the hill. if you were going up a fairly decent hill than you would've been putting more of a load on the engine than if you were cruising along a flat stretch of road.
Its a hill that climbs for a good kilometer or two.
It starts at the bottom of a valley, so initially its quite steep and it takes ages to be back on flat land. I started hitting 5k rpm when it was about halfway from being back on flatness. It was really weird because it wouldnt rev any further but was nowhere near the limiter
I was driving normally down the valley, once i got to the bottom, I chucked it into fourth and it started boosting a bit, so i thought sweet, chucked it 3rd, it launched for a bit, once it got to 140 it wouldnt go anymore
so it had only been under boost for about a minute max before it started to hold back
I have seen this before on a dyno, problem found to be a boost leak
I dont know if it could be a boost leak, I take care of my car, then again you could be right. I change the oil every 5000, and then a mechanic looks at it all over and tells me any problems, the gaskets of the turbo were replaced but it shouldnt be leaking now. However, mechanics can be scams
 Share
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
