Probably a stupid question with a more then obvious answer here. But is there a difference between the R32-33 poncams to the R34 ones? The reason I ask is I had to re-order my parts again (parts were stolen from the workshop) and have only just realised that I have ordered the R34 poncams 260/256 9.15mm, instead of the 32/33. Can i fit them or no?
stew
https://www.sau.com.au/forums/topic/81265-poncams/
i would get the right one if i were you ,save your self alot of head aches, the cas pick up drive are totally different and unless you want to buy a r34 cas($$$) the exhaust cam won't be of much use to you. If the order is beyond return just less the cams on the forum as they are a very sellable item and order r32/r32 units that will bolt straight in.
pete
https://www.sau.com.au/forums/topic/81265-poncams/#findComment-1476678
And with the Yen the way it is now, buy them asap :P
Just to go off topic a little, but is it my imagination or do the prices on some of the popular sites -- e.g. Nengun -- stay relatively stable regardless of currency fluctuations? I mean I've been watching some of the parts prices and despite the high exchange rate they don't seem to have shifted...
Edit: Sorry, that sounds like a complaint: its not meant to be :) Just an observation. I assume they build in a couple of Yen safety margin.
https://www.sau.com.au/forums/topic/81265-poncams/#findComment-1477770
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • A mini mini-gun.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
