Need info on trainstops to get off on etc.plz help
daveR32gtr
 Share
Hey all. going to japan soon....will be in nagoya and tokyo (shinjuku) want to go to autobachs or up garage...can someone tell me the lines to get off on...what stops etc or any directions on how to get there etc would be great...really need rail info etc
thanx in advance
The best thing you can do is to find and print out the adresses to Autobacs and Upgarage and ask in Japan.They will help you at the hotel or information etc at the train stations.
http://www.upgarage.com/upgarage/index.php
http://www.autobacs.com/cgi-bin/inetcgi/sc...session.new=Yes
I think Blitz posted up detailed directions on how to get to SuperAB Tokyo Bay? Do a search, I'm sure it wasn't that long ago...
Can't find Blit's directions by using the serach function... I think it's broken?
Maybe PM Blitz or mmmgtir as those guys are well experienced with getting to shops around Tokyo.
theres also Super Autobacs in Yokohama which is close to the Minato mirai station... if you wanna know let me know... if you are in Yokohama go to China town cos its the biggest in Japan...
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
