Must Sell A.S.A.P.
Blitz LM Front Mount Intercooler Kit will suit Series 1 R33 GTS-t (ECR33) comes with all piping, brackets, hoses.
Perfect condition - rated up to 650hp, will bolt straight on to existing piping. Size - 610mm x 266mmx 68mm
All offers considered asking $1250 ono.
Must sell due to plenum upgrade.
A pic below..currently fitted 2 my car.
https://www.sau.com.au/forums/topic/81290-fs-blitz-lm-intercooler-suit-ecr33/
oh really? shit, i had no idea hey
i bought mine from Autobarn 4 $1600 so was just working off that...
like i said tho ONO so if ur interested, make & offer & i'll definitely consider it :-)
Hey there just wondering where u were located, i am in canberra, would u be willing to ship it over here?, any minor damage at all? how logn ahs it been fitted to the car?
thnnx
Semo
i'm in brisbane - willing to ship @ buyers cost.
fitted to my car for about 12months (although for approximately half that time has been off the road getting new mods etc.)
1 minor scratch on top of core & a few stone chip marks on core - very minor - otherwise very good condition - works 100% - only selling due to plenum upgrade.
must sell urgently now - anyone?
  • 3 weeks later...
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
