Hey guys :D
Just wanted to know if anybody has ever used on of these turbos on an RB25?? I have a 3037s at moment and I think that will limit me to around 300rwkw and id really like to see 350+rwkw.
I was thinking the 3240 would make this sort of power without having too much more lag than the 3037 :confused:
All the necessary mod to support it like forgies, rods, cams, front facing plenum....... etc
Thoughts anyone???
From the HKS USA site the GT3240 (GT5982R in new speak) is a tad smaller in the turbine dimensions ie 58.7 x 54mm vs 60 x 55mm for your GT3037S . The compressor the former uses is an 82mm 54 trim GT40 series wheel . How they come up with the 580 PS power rating beats me . Also note that its sold with a .87 ARR T28 flanged exhaust housing .
You may be better off looking at the HKS version of the GT3040 which has the same turbine as your 3037S and a smaller (50 vs 54) trim 82mm GT40 compressor . Its still not a good match in my opinion but looks better on paper than the 3240 and has a few more turbine housing options .
What turbine housing does your 3037S have ?
Cheers A .
Sorry dude should have said my turbo is accually a 3037 Pro s, internal wastaged, not the external gated 3037s. My turbo has the .87(? I thinks ?) A/R T3 flanged exhaust housing.
Righto these are the specs from the turbo we has mentioned straight off HKS USA website, now most of these number dont mean a great deal to me could someone please explain??
discopotato - why dont they look good on paper? Im still learning how you match all this stuff up :confused:
HKS GT3037 Pro S - 480 PS Output
COMPRESSOR:
-Wheel- 56 Trim - 57.0 Inducer / 76.2 Major
-Housing- 100 Inlet / 50 Outlet - 0.60 A/R
TURBINE:
-Wheel- 84 Trim - 60.0 Major / 55.0 Exducer
-Housing- T3 inlet / External GT-Pro outlet; 0.68, 0.87 A/R
HKS GT3240 - 580 PS Output
COMPRESSOR:
-Wheel- 54 Trim - 60.3 Inducer / 82.0 Major
-Housing- 100 Inlet / 60 Outlet - 0.60 A/R
TURBINE:
-Wheel- 84 Trim - 54.0 Major / 58.7 Exducer
-Housing- GT25 inlet / External GT30 outlet - 0.87 A/R
HKS GT3040 - 500 PS Output
COMPRESSOR:
-Wheel- 50 Trim - 58.0 Inducer / 82.0 Major
TURBINE:
-Housing- GT25 inlet / External GT30 outlet; 0.61, 0.73, 0.87, 1.01, 1.12 A/R
They don't look good on paper because of the size difference of turbine to compressor ie 60mm to 82mm = almost 27% , 15-20% is preferable . At least the 50 trim of the compressor helps .
I don't think you mentioned anything about AFM size/exhaust manifold type or if high performance cams are used . There are lots of options ie the cast HKS exhaust manifold/external gate teamed with the larger 1.06 ARR turbine housing . I would check for pressure drop across the intercooler as well .
The RB25 top end if its std may be lacking in the breathing dept so porting/cams/springs or the best option RB26 top end may pay off .
If your looking for a bolt on turbo solution I guess the XR6T's version of the GT3540R could do but its asking the turbo to do all the work probably with a highish boost threshold .
Cheers A .
Thanks disco :thankyou: to answer some of your questions though. Car runs a MAP sensor so no AFM is used just a 4" intake pipe plus 4' exhaust, if I were to upgrade to a bigger turbo a tuned length custom manifold would be used, the head has been ported with uprated spring etc plus HKS cams with higher lift etc also plus a front facing intake plenum.
So how do I go matching turbo with the engine and the power/responce im after?
:D
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
