Drift1 racing Intercooler kits
D1 drift and racing intercooler kits - one of the highest quality kits on the market. Now can be purchased without the a group buy at a extremely low price!!!.
For the next 10 kits only all piping kits are delivered for $350 and full kits are $530.. number of kits at this price left = 10
SPECS
Made from polished aluminium with no mandrel bend marks on any of the pipings. Piping is 2.5" and is very similar to the hybrid kits. The flange on the end of the piping is bigger than the hybrid kit for added support.
Silicon joiners are triple layer with chaffing on the third layer.
Clamps are stainless steel
All kits fit perfectly on the R33/R32 and the s13/180sx. When these were manufactured they were also tested on sample cars and the samples have also been tested in Australia. Many people have bought these kits without a single complaint
Will fit most hybrid coolers.
BONUS: All kits come with the nipple to hook up the turbo boost line too. Save a few $$$
Warranty
All kits are backed by an australian warranty 1 year.
Price
$370 delivered for the piping and $550 with the cooler (600 x 300 x 76 mm)
Arrival
Here now ready to go.[/color]
  • Replies 104
Ive already done a fair bit of mods to the back of the plastic part of the bumper and the front section of the chassis rails to mount the intercooler in there. As far as I can see I just need to cut and shut the two lower pipes to fit the extended end tanks, possibly using a silicone joiner, if not re-welding. This seems the best option short of making a custom set of pipes, which looks like costing around $300-350 in stainless mandrel bends and parts, let alone labour and hassle.
it curve round and come back over the top of the radiator and fans? yes that the one..
Just off topic: My mate has a s13 and just put one of my cooler kits on it. My car would be a mid to high 13 if I had decent tyres otherwise it is a 14.051. Anyway he flogged me (2 cars ahead at 140k) and this is the only mod he has done. Oh and apart from the fact that he forgot to hook up the wastegate :rolleyes: 15 PSI he was running. No ping either... Maybe because the cooler is working well - hot on the turbo side and freezing cold on the other...
I just installed mine on sunday :) ... Yeah I had to move the horn. I placed it on the bonnet hinge bolts.. The wired will reach it you unclip one of the tyes...
IT took me 7 hrs to install the kit but that because I took my time painted painting the cut surfaces so it wont rust and trying to do a nice job... I forgot to get my camer and take pictures :) but I will take a few picture after my camera is charged an post them up...
I got an extra 1 psi and really noted the difference after I reset the ECU... if I take off like a grand ma, first gear starts spinning the wheels after 4000 rpm and spins most of second gear :) little chirp in 3rd.. Once I start playing with the boost then I should see some action...
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
