  • Replies 104
What is the piping like on the inside.
I just saw some real bad piping kits on NS.
Inside the piping was really bad.
Have u seen the topic posted.
How are these kits on the inside they look really good on the out?
Pics if possible.
Thanks
THe piping is great on the inside, No problems. Mine had a little bit of grease from the mandrel press I just presure hosed it out..
I haven't seen the topic posted but I have seen some bad kits on sau the welding was crap!!! ... This kits only has 1 weld and that is for the boost line... Perfect weld.
Ask the others who have bought this kit. Not one complaint :P ...
Trust I would be putting this kit on my own R33 if it was crap.
yeah just read that thread on NS.. Apparently the kits where made from copper and pvc piping.. well I can promise you my kits are made from aluminum.. Man they must have been cheap..
how many kits for r32 u got left? coz if u can buy one now n hold it for me for like weeks ill pay u $450 for the kit sent to canberra wat u say? if u wanna ask me any questions jus call me on 0432453535 ok thanks
Edited by cuong nguyen
Great quality kits, and very easy to modify if you have something other than the standard 300x600 intercooler. Heres some pics of the kit modified to fit a GTR intercooler in an R33 GTS-T.
Edited by courier33
Just picked mine up then.
Verrry good piping, really impressed.
Cant wait to install it.
Pictures coming soon.
Thanks Rafnel.
Edited by Justin O
  • 3 weeks later...
no probs dude. Im glad you liked the kit.. Still a few kits for sale..
looks great man, just one question, the crossover pipe looks to be very close to the fan blades? once the bonnet is shut and you hit a few bumps.. u sure it wont touch ? Also i noticed the pipe is up against the hot radiator hose .. will this affect performance ? other than that looks smick !
onBOOST247: No the piping does no move around because it is locked in via the hole you make on the driver side and the piping it joins into on the other. Radiator hose , yes it in close but nothing to worry about.
I had to cut the fan blade a little bit off the edges. Motor temp is still the same.
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
