Hey Ppl
Ive just been doing dome searching on upgrading my turbo. I have found plenty on turbos that will fit the standard exhaust manifold but i can't seem to find a turbo that will also fit the standard dump.
Does anyone know of a upgrade turbo which will fit the manifold and dump.
The reason being is that i have just recenetly bought a BOS importing front and dump pipe, this bolts directly to the stadard turbo with a seperate exhaust pipe and wastegate pipe.
Any help would be great. If i can't get a new turbo to fit then i might consider a GCG rebuild and hiflow for $1900. I'm not really that keen on gettin a new dump made up and selling the BOS pipe as i know i will lose money and im not the richest kid on the block.
What do you guys reckon?
https://www.sau.com.au/forums/topic/81325-question-on-turbo-upgrade-r33/
hks gt2530, hks gt2530 kai, hks gt-rs, hks 2835, apexi ax53b70 and some of the trust low end td05's i think should all match the stock dump flange. the highflow will also match. if you are looking at turbo change make sure you have fuel pump, injectors, airflow meter, ecu, clutch, fmic, cold air intake kit and some good tyres to get the best "benefit" from the turbo change. also consider lag vs response. hiflow shoud good best response. boost wont make power, airflow does so dont get a turbo and run 25psi just cos you can, get one that will give you good power at 1.3bar or thereabouts. check the "rb25 turbo upgrade" thread stickied at the top of forced induction. should have plently of info for you
