I'm like sitting here thinking to myself...............duh! what's the worst movie ever and I can't think of one for the life of me! I've seen heaps of shite movies! (thinks I've brained my damage!) What about The Warriors!!! I laughed through that one!!
But I have to say the all time best movie I love is Pulp Fiction!! :) I lost count how many times I watched it at the cinemas! and DVD! I watched it not long ago, they re-ran it at Luna Leederville, followed by Fear & Loathing in Las Vagas (I thought was well done too) Bluddy brilliant!!!
  • Replies 135
iam with Zahos "SAW" is one of the best movie's i have seen in along time since butterfly effect directors cut and army of darkness.
worst:the new fraken starwars movie ep3 man that just sucked all the new starwars suck that shit sould of been a min series or sumfin adn eny movie with singing (unless directed buy mel brookes or made by monty python) also any holly wood remake of a jap horror film
wow so many to choose from
im gonna say Crossroads - the britney movie
and Evita with madonna singers shouldnt act
oh and you got served such bad acting they shudda cut out all the acting scenes and left the dancing
and son of the mask, dumb and dumberer who the hell decided to remake these sh1t films
and garfield borinngggg
and Gigli fairly obvious
and alien Vs predator that was super crap
streetfighter that was craptacular
blair witch project so scarey i fell asleep
and anything with steven segal in it makes me wanna barf
i didnt even bother seeing most of the movies you mentioned 33Spec2 - guess i was right not to :thumbsup:
only good bit in blair witch is the last scene when one of the characters comes into the house and sees the other one already in the corner.. thats awesome mind games...
slightly off topic/
we saw Sin City the other night... anyone notice how much Kevin looks like Harry Potter ;)
anyone notice how much Kevin looks like Harry Potter :thumbsup:
Are you implying Harry Potter is actually a stealth serial murderer cannibal? I’m sure it’d make things more interesting if he was… hahah
Kevin actually reminded me more of the guy out of the Matrix with those sunnies. The Chinese fighter guy.
hahah... we were thinking we should adapt a couple of kevin's scenes, rename it and upload it... so that when the little kiddie's download a new, leaked snippet of the next film, "Harry Potter and the stones of Roark", they get the suprise of their lives...
either that or a different version of LOTRs, since Kevin is Frodo :thumbsup:
Mwahhahaha
Zoolander was excellent. "It's not like we think we're actually in a control tower trying to reach outer space. Hello. Hello."
And Malkovic was cool too but my gf can't stand it.
The worst ever has to be Killer Clowns From Outer Space.
Did anyone ever watch that movie by Peter Jackson (who did son of rajab of the rings) called "bad Taste"? Its was this Uni assignment grade horror movie where zombies at peoples brains. I think it might actually beat Spanglish as the crappest movie hahaha
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
