Hi, I've just bought a Greddy V-Spl cooler (yet to fit it), and was just wondering a few things...
1. Is a pod filter needed (i.e. cannot use the stock airbox) for one of these on a 32 Gts-t?
2. Do u need to cut a hole in the arch (wheel) to accomodate the piping?
3. Is it a simple bolt on, or is a bit of stuffing around need to bolt these things up.?
4. Is a different Battery needed for this cooler (to make way for the piping)?
5. How do these things go as far as radiator flow?
6. How do these rate against the stock cooler?
7. What boost is anyone running with one of these on an RB20DET?
Any help would be appreciated...
Cheers David
https://www.sau.com.au/forums/topic/81363-r32-greddy-vspl-intercooler/
Cheers David
1. No standard airbox is fine.
2. Hole in the wheel arch???
3. It's a straight bolt on and only very minor modifications are needed to fit it.
4. All depends on the size of your current battery as they come from Jap land with heaps of different styles and sizes.
5. Your radiator will still get ample air flow.
6. Flow much better than the standard cooler.
7. If the only mod you have/will have is a cooler and say exhaust, about 12 psi would be ample. If you would like to run more boost, it is recommended that you upgrade your fuel system and either remap your standard ECU or get some form of aftermarket ECU.
make sure u have all of the support mods like said above..
get exhaust- prefferably turbo back, i.e dump pipe, front pipe and cat back..
get a panel or pod filter... a fuel pump is not needed if ur running abt 12 psi..
however, a tune is defenite... Get a piggy back ecu if u can afford it like an SAFC or emanage, or even get ur stock ECU remapped...
its all in the tune.. it does not mean the more psi u run, the more power u will achieve..
hope that helps..
Rob
Hi, Does anyone know if the R34 VSPL Intercooler kit its going to interfere with the standard snorkel and after looking at the pics of what comes in the kit, do I need any additional piping made up or does it just use the existing piping?
Thanks heaps. Pics if possible of what comes in the kit would be good (if it isnt what is shown on www.nengun.com). I have a cold airbox that uses the factory snorkel at the moment and wouldnt want make it a waste when i get the cooler.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
