Had a problem which has been going for a couple of months and is starting to annoy me. When i put my foot to the floor and the car revs really hard sorta towards the limit before I need to change gear the car starts to lurch forward and just choke. Usually the car will just keep going and going nice and smooth and continue to rev high. But lately it just keeps doing this. It is seriously affecting the performance and quality of the car's ride.
https://www.sau.com.au/forums/topic/81388-car-choking-under-high-rpm/
Pat. It's chris mate.
1. check sparkies. cheapest and first thing to check. I'd recomend the bcpr6es (copper ngk). Stock r33 gtst is meant to run the 1.1 mm gap and 5 heat range. because yours is running exahust, boost etc, run the 0.8 gap and the 6 heat range.
2. coilpacks. Due to the location of the coilpacks right above the engine, they get very hot. They are, believe it or not made out of plastic, and the plastic cracks over time. Pull the coilpacks out and check for cracks. When I say cracks, I don't mean like massive ones. They form hairline fractures. Also check for burns on the plastic, because this may indicate that they are cracked, and the sparks are leaking out. (As said in 1. by running a 0.8mm gap spark gap, this can reduce the effect of warn coils. Reason? The spark will jump to the easiest place possible. If you run a larger gap like 1.1mm, it may be easier for the spark to jump out the edge of the coilpack through a crack).
3. AFM - you're running a hks pod which is oiled. Pull the pod off, and rub your finger on the black plastic inside the AFM. you'll probably notice your finger will be black. I did on my car, and it was. Solution? Contact cleaner from Dick smith. spray the shithouse out of the AFM element and watch the black stuff run out. (hehee, I suggested to do this last time).
4. How much boost are you running? when the stock ecu senses too much air flow, it goes oh shit, because stock, they're only meant to run 5/7 psi. It richens the fuel mixture and severely retards timing. It sorta feels like you've hit an invisible wall. It's quite violent. I found on my car that it started happening at about 11 psi (with full exhaust, pod, cooler, etc).
You'll have to take me for a fang to show me what it feels like, because if I remember correctly, you were running about 10psi. This is about borderline for rich and retard because you don't ahve fmic (stock ic then becomes quite restrictive as you increase boost).
Obvious things:
1. are you running good fuel? ultimate?
2. have you had your fuel filter changed recently? your car might be leaning out due to lack of fuel from a clogged fuel filter. unlikely though.
3. tried resetting the ecu? some notice it does something, others don't. I do.
4. how old is your cat convertor? is it blocked? quite unlikely though.
5. any vaccuum leaks anywhere? like any dodgy arse looking old hoses anywhere?
hmm... that's all I can think of atm. I just got back from work...zzzz..
Cheers
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
