hey dude.....
how many km's on this turbo??
is it t3 flange??
any shaft play in it???
how do u think it will go on a rb20???
cheers
~~GIFFO~~ .............. very interested!
hey dude.....
is it t3 flange??
cheers
Yes its a standard t3 flange - because its a vg30 rear housing - stock nissan housings - even your rb20 dump pipe will fit and it will fit onto your exaust manifold.
its probly done 20,000ks + - i do alot of freeway driving.
I dont know if there is any shaft play because I have not had the turbo off since i put the rb30 in (about 15,000km ago) and it was fine - the turbo still works and makes big power so it is ok.
It would go hard on a rb20 - have heaps of top end as well as a rb25
The front inlet of the turbo is heaps bigger then stock - you need to mod it to fit - very easy to do - if you want we can do a deal with all my old stuff to fit it and i can make new stuff for the gt3540 :rofl:
EDIT: Forgot to mention - you dont need a spacerplate on the exaust manifold because the front housing clears it fine :)
I wont be on much on the weekend so if you have any questions call 0432254403
im interested.... ill have to check my bank though.
cheers
Linton
Seems like the guy who came over (made me take the intake pipe off to check the turbo for play) who put a deposit on the turbo smashed his car up tonite so he cant buy the turbo.
Still for sale.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
