I recently purchased a Clarion CD player from a local Police Clearance auction (they sell stolen & unclaimed goods direct from the Police Dept). I tested the unit last night and all channels, CD and radio work fine but after but after 5 minutes, the word CODE is displayed on the screen. Of course being from an auction I don't have the security code.
The model number is PM-2308U-A, and it looks like a unit that was supplied as a standard unit with a new car but have no idea what type of car.
Is it possible for anyone to aid me with this problem? Or am I stuck with a dud? :lock: btw - I do have the receipt to prove it's not hot.
MearCat
https://www.sau.com.au/forums/topic/81397-security-code-on-clarion/
if thats the case ,the unit you descibed is from a mitsubishi of sorts - usually a lancer.) they are fitted locally here and if you take it to a service shop tell them where you got it and leave it they can get the code out of it. ( involves a call to clarion.)
  • 4 years later...
MearCat
I'm trying to refit one of these to my Lancer and have my code but no manual so don't know how to key it in. Can anyone help me with this. :D
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
