Thanks guys, picked up what i wanted from the 300zx forum.
Apexi USA, only have the earlier model with the four buttons shown, i wanted info on the later model one with 1 button.
Also told Apexi is going to the wall, and their website is about to be pulled.
set in your weight and tyre size, should correct it. i believe the rsm is more accurate with weight put in and tyre size correction
Already done that, still have a diff reading on PFC than RSM... its odd.. the RSM seems to be the exact same as the dash readings, where as the PFC is a little less...
I would assume the PFC to be more accurate, since this is a full stand alone engine managment system?
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
