I must be having a dumb day...........how does cleaning the injectors improve the fuel economy?  Surely a dirty injector flows less, so the fuel economy should be worse when it is cleaned and flows more.
The ECU doesn't know that the injector is dirty, it still opens and closes it according to the mapping.  In closed loop running, the ECU aims for 14.7, so it doesn't matter if the injector is dirty, 14.7 is still 14.7.
As I said, I must be just having a dumb day........
:( cheers  :D
Below is what I visualise how a clagged injector could possibly increase fuel consumption.
Say we have a clagged injector or two that atomizes badly and flows less.
The O2 sensor only views the overall afr, not the individual cylinders.
As a result one or two of the injectors will be flowing less and atomizing fuel badly.
As a result, less fuel flow in to those cylinders is going to increase the afr that is seen by the ecu via the o2 sensor.
As a result the ecu increases duty cycle slightly to bring the 'overall' afr in check.
As I said.. That's the way I visualise the inner workings. :)
I would really like to know why some rb's are better than others on fuel.
My R32 has always been decent, changed to a bigger motor and its hardly changed, not to mention its always on boost due to the small turbo that is hanging off the side of it.
I'm almost scared to swap in some larger injectors. lol
Edited by Cubes
  • 1 month later...
I finally got over 400KM on a tank of fuel, 409km and filled up before the fuel light came on. Thats a record for me!
Edit: I think the light flicked on for 1 second at some stage though. It does seem to slow up a little on takeoff with a full tank ,all that extra weight.
BEFORE the light!
WOW!
I get to about ~380 and then the lights on/off a lot, then at about 400 i get it always on and the car doesnt start very easily on a slight hill
Then at ~410, i fill up and put in 63L's
I know i push it :P
Well, just filled up. 1st FULL tank Ive used since the dynotune service with new O2 sensor.
55.8L filled it right up to max, and did 391.5km for that tank. The fuel gauge light was just starting to flicker.
That equals exactly 7kms per litre, or 14.3L per 100kms. And I was certainly using 'boost' during this 391kms!
Edited by bwilkeson
NRGIZD, like i said, i have a DFA here and built which i wont be needing anymore due to getting a power FC, they RRP at 79 in kit form, and i dont mind giving mine to you at that price built.
You will need the hand controller with it too, but they are pretty easy to build as well (i need to keep my controller for my EBC)
The DFA is also pretty easy to install, and i can also just send you right to the person that was going to tune mine with me Dr Drift.
Grab the SAFC-2 off ebay, for under $400 brand new. Cant go wrong with the Apexi...............
See thats what l was thinking, esp as the workshop l use know them very well.
Might have a sit and think on it, are the hand controllers hard to assemble?
When I first bought my stagea I was getting about 300km to 50ltrs not going over 3000rpm. (Mixed Driving, Sydney & Freeway)
Then autostyle did a service and changed spark plugs, O2 sensor, high flow filter eliment, cleaned all the throtle body, injectors, fuel filters, etc and now I'm getting about 450 to 50ltrs. Not hooning but not granny style like previously.
I also drove to QLD and was achieving 560-600km to 50ltrs.
Car is still facotry standard other than the high flow air filter element.
Given that is the first post by that ID, and their link is straight to autostyle, you have to wonder about how genuine that comment is.. Care to comment about what your association with them is, and what stagea you drive?
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
