does anyone know at the diffrence between a standard r33 gtst and a nismo plated r33 gtst would love to know as ive got a nismo plated r33
and im running as follows
t70
bosch 044
fmic
50mm external w/g
malpassi fuel pressure regulator
stock ecu i think
stock internals i think
stock driveline i think
and pushing out 289.6 rwkw
should push more
any info would be a great help :confused:
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/
mate if it's really in 'chinese' you're in trouble...LOL but i know what you mean. do you have pics? either you have just a badge, or some serious stuff there, but if it's really nismo it's more likely to to be internal if anything, ext wastegate etc doesn't sound like the typical nismo approach. any clues on the car etc ie different vin to other 33's?
i think funky monkey knows a bit about vins etc might be worth a pm to him.
interesting location by the way, what's it like there?
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1480471
ill try and get some pics of it and ill also try and get my vin number and hopfully someone knows out there cause ive being woundering for a while
i have not touched any internals or ecu
the ecu is good only cut is speed car has not detonated or anything and im running high boost has not stuuggled at all thought i might ask before go pulling it down to find out whats inside
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1480489
that much power and stock injectors and stock ecu = :Bang:
never heard of nismo plated
post up the vin should be ECR33-xxxxxx and i can check it in fast
sounds like just a normal mspec with the aftermarket stuff thrown in
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1481066
i havent even told you wat boost im running yet then u will be even more shocked :crazy: this is wat i cant get over the has not pinnged once nothing of the sort no sign of struggles no knocks, the car spiked to 32psi on the dyno once and nothing happend shit myself at the time was a fault with the boost cotroller it had a kazz diff in it but no longer would like to get it back im the second ower of this car im only asking cause there are a few of these in mildura but none with this plate under the bonnet ill get the numbers tomorro as its in the workshop gettin a plenum done
how do i test the flow my injectors as well :confused:
thanks everyone keep it comin cause im dying to find out
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1481111
Josh
punctuation is your friend. I'm not even going to bother trying to decipher this mess until it's been edited.
Tip: if we can read it, we can help.
im sorry that my education skills with computers is not up to others standard :confused: im just after a lil help i just want to know that if anyone out there knows wat this nismo motorsport badge under my bonnet is
does anyone know boost a rb25 can handle with the mods i have done cause mine atm can easily run 22psi has being running 20psi for the last 6mnths
and i drive it everyday
thankyou
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1481259
nismo motorsport is the nissan well motorsport department, much like hsv is for holden or fpv is for ford. so its badged by them for some reason. the amount of boost means nothing at all. the heat generated by running that pressure will kill your engine not the boost. sort out what ecu you have and what injectors so then your tuner can decide wether its safe or not. you can run 56psi for all we care, this doesnt mean youll make more power but it does mean youll make more heat. heat is what will kill stuff. and you have stock internals so be careful until you get checked and work out what hardware you have
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1481396
ill get it checked but i dont think the heat that the motor is producing my tuner that has done all the work to my car has bein in the industry for more than 30yrs has not seen anything like this the car has a massive fmic and the turbo has a heat blanket on it have had a fair amount on the dynoand the results are great with more power to come with new plenum and other lil things i dont belive there is any damage being caused to the motor from this and cant say i have stock internals cause no one know spose beat bet is to pull it down but dont see that happening in the near future lol
appreciate all feedback
tryed my local nissan dealer dont want or know anything about imported skylines lol
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1481512
the plenum wont make any difference to the heat generated. the massive fmic wont cool the heat charge coming off the exhaust and spinning the exhaust wheel at a billion revolutions per minute. just get it all checked and find out exactly what you have
https://www.sau.com.au/forums/topic/81516-nismo-plated-r33/#findComment-1481518
